#11 |
You mentioned the word travel. This is an interesting term that can be played with.
Conditions aside (blah blah), sound travels at a certain set velocity regardless of frequency. If the frequency is high enough that a wave cycles from compression to rarefaction before the compression travels across the inside of the enclosure, it could be said to travel as it appears to do so. On the other hand if the sound cycles slowly, the entire box fills with the compression and the rarefaction independently and in turn. Thus it is like blowing up and releasing a balloon, and I suspect this is the distinction your friend is making when he refers to low frequencies. Anyhow, dealing specifically with this low frequency effect is just as BassAwdyO says where you tie the centres of the panel together to stop them 'breathing'. Some thoughts. So perhaps since the low frequency effects are all encompassing within the cabinet, I feel it's hard to say that the waves will meet the braces like obstacles as pressure equalises on all sides of the braces. OTOH, I do feel that higher frequencies may dislike the braces more (consider diffraction and reflection). In practice, braces can be made non-intrusive by rounding, keeping a low profile, and adding damping material. Still though, I use external braces in the locations where I can get away with it. In closing I'd like to mention a point that Rademakers made. Bracing can be more effective than thicker panels. Though this has a practical limit (don't use cardboard ), a heavy panel can store more energy than a light one. Lack of mass is good, and stiffness is good, or more to the point, it's the ratio of mass to stiffness. This is largely why bracing is good.BTW, dense hardwood makes the best braces in my opinion. |
#12 | ||
Bracing isn't likely to have an impact on SPL, except in the most extreme situations. It's purpose is to make the box more solid and reduce the requirement of thick walls. It will only impact SPL to a significant amount if the walls are FAR too thin.
Air flow does not occur inside a subwoofer box. Sound waves are a pressure disturbance where air particles jostle each other and pass on vibration like a chinese whisper. Picture a cork floating on water when a wave comes along. It moves in a circular motion but does not flow with the wave. The wave moves along, that is the disturbance. But there is no flow. Bass won't travel as a wave inside a subwoofer box. This occurs in the midrange, but in a subwoofer box, the wavelength is so much bigger than the box that it is not possible for reflections to occur. What happens instead is that the box is pressurised. A 40 Hz sound wave is 8.6m long, much bigger than a subwoofer box. An 80 Hz tone is 4.3m long, again much bigger. If your friend is talking about a subwoofer box that isn't insanely huge, then the problem is imaginary. Quote:
For a box where midrange is present, the sonic impact of the bracing becomes an issue. As I recall, B&W use foam in the holes in the bracing to mitigate this, but this is irrelevant to subwoofers. You should avoid holes in the bracing that are too small as you don't want to add resistance to the pressure moving through the box. If the box is vented, then aerodynamic factors come into play, especailly around the ends of the vent, both internal and external. You need internal clearance around the vent, otherwise the tuning may be affected in ways you can't predict resulting in a less than optimal response, and you may get some turbulence reaching audible levels. It gets more difficult to design the bracing where you have to accomodate a vent. If you have a small box this gets more difficult, although the requirement for bracing then is less and you can focus on thicker walls more. But in this case, with a high excursion driver it will be very difficult to fit in a vent that won't chuff like mad.
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#13 |
Paul and Indm hit the nail on the head...
The golden rule of DIY: Build nice, or build twice! |
#14 |
WOW!
#15 |
Oh! Im coming with other points. Im gonna talk at this place with 3 points:
First point (retake again what has been talked before): In a subwoofer, there is airflow. In other words, when the woofer moves, there is airflow in the box. I am conscious that bass waves are very long waves, therefore, reflection and refraction doesnt occur, but only pression. However, when we talk about pression variation, we talk about air movement in the box. So braces can restrict air movement in the box, thus, reducing somewhat the maximum SPL. Second point: Basically, with a port, there are shock waves which travel in the box and more the ports are able to sense them, more they are effective. Third point: If the port is not placed at the opposite side of the woofer (for example, woofer in the front and the port in the back), the port becomes more leaky and the ported box doesnt have as much SPL. It seems to me that the third point doesnt make any sense, I have never seen this kind of affirmation before! What do you think about all of this?
#16 | |||
)Quote:
#17 | ||||
In both sealed and vented boxes, bracing should be designed so that all sheets allow the sound waves to pass through. As a result, the bass will uniformly pressurise the entire box. The fact that sound waves have to pass through openings in the bracing does not mean SPL will be reduced. Try this. Turn on some music with bass. Go outside the room with the door 2" open. Now open the door half way open. Does the SPL for the bass change at all? Of course not! It's the midrange and above that changes. Bass will pass through small openings easily. It is the same inside a box with bracing. Quote:
I have no idea what you mean by that! This is what you need with a port. First you must have the correct box volume, as this will determine the efficiency of the port. If the box is too small, you won't get enough output from the vent. This also relates to tuning. The lower you tune, the bigger the box needs to be in order to get enough output from the vent. You can see this going on in WinISD or any simulation program. Secondly, aerodynamics are important. The port must have enough cross sectional area that the air velocity is below 34 m/s which is the absolute maximum. The velocity that is ok at the inside and outside ends of the port termination is dependent upon aerodynamics, and must generally be a lot less than 34 m/s to avoid turbulent noise. Large flares help a lot, but even a large flare will typically need air velocity to be below 17 m/s. If the air is forced to move at high velocity, the resistance will lead to compression, which means the SPL will be reduced slightly. If the bracing in the box had very small holes to let the waves through, you might have problems. This would add resistance and could cause the box to act as if it were a different volume of air. The result would probably be loss of SPL, although not siginificant. If the holes are at least 3" I see no problems here. Quote:
#18 |
Of course the air is moving in a sealed enclosure, granted it's not moving very far but it is moving, if it didn't move then adding fill (resistive damping) would have no effect.
If you add fill to a sealed enclosure you can lose up to 3db off the resonance peak. This is direct evidence of "stuff in box reducing spl" (though mainly at resonance) You go silly with bracing in a sealed enclosure and you will add a very small amount of resistive damping into the enclosure that wasn't there before. Sure the difference it makes is unlikley to be audible (and it will be swamped by the positive aspects of the bracing) but that doesn't stop it from happening. More evidence of this somes from the guys competing in car audio SPL comps, where they use very high Q enclosures to extract every last Db possible. Now they may be crazy but they aren't stupid, the top guys do not use extensive shelf style bracing in their enclosures, even though that is a very effective way of making an enclosure strong and stiff (which is what you would think would be best to achieve a high Q) Instead they use multiple layers of wood and/or concrete with very sparing use of steel tube/threaded rod bracing where strength can't be achieved any other way. They do everything humanly possible to avoid putting anything in the enclosure. That's a lot of trouble to go to for something that supposedly doesn't effect SPL. I'm not advocating that the resistive effects of bracing makes a noticable difference in most "normal" applications, it's just bad science to state that something has has no effect when it actually does, no matter how insignifigant, especially when in extreme suitations it does have a substancial effect. |
| Subwoofer enclosure internal bracing | rocko1290 | Subwoofers | 10 | 1st September 2006 03:04 PM |
| Does A Box Like This Need Bracing? | sdclc126 | Subwoofers | 10 | 12th May 2006 02:31 AM |
| Enough bracing? | Vikash | Multi-Way | 51 | 8th May 2006 06:58 PM |
| bracing of large cabinets and effects on internal reflections | JRKO | Multi-Way | 7 | 12th April 2005 08:12 PM |
| enough bracing?? | Chris8sirhC | Multi-Way | 3 | 31st January 2004 09:16 PM |
| Page generated in 0.18662 seconds (79.86% PHP - 20.14% MySQL) with 10 queries |
