I found this on eBay.
http://cgi.ebay.com/OEM-DSW10-10-SUB...QQcmdZViewItem Is this the same one used in some of Kenwood's subwoofers? Or is it car-audio trash? |
#2 |
It IS OEM, can be good, maybe the customer from the factory went bankrupt? It's worth a try for that price, always good as a test speaker (I kill a lot of them on testing amps...).
Max. cone displacement can be several foot on any speaker!Too bad it can be done only once......
#3 |
Weight is stated at 5.5lbs. Seems REALLY light for a 10" sub. This picture would leave one to expect it to be much heavier.
#4 |
Maybe it has a plastic magnet!
Or as I've found on Tandy's "realistic" woofers years ago partially plastic "magnet"...
#5 | |
You don't insult our RadioShack fullrange speakers, and we don't drop a cow on your house from orbit. And now, back to our regularly scheduled programming. |
#6 |
Yea it could be buyout/clearance stock, I bought 30 12'' woofers a few months ago for $11au each (~$7us) that were clearance stock.
#7 |
greetins Volenti, were those the eminance beta on ebay, au there must have been a @#*& load of them as Ive seen them turning up in pawn shops ten at a time. Let us know if you want to sell any, I may be interested in four to try a dipole/ripole number
cheers fergs |
#8 |
there's a $ 15.99 shipping charge with that.. not all of that would be paid to UPS!
you'd be surprised what it costs to make that speaker. here's how it's done: CONE: BLACK TREATED CURVED PAPER (cheap Foam surround) COIL SIZE: 1 1/2" (paper or nomex form) EFFICIENCY: 89DB (just a number) IMPEDANCE: 6 OHMS POWER: 100 WATTS RMS (Sure) MAGNET DIAMETER: 4 3/4" (that's the OD.. normally, the ID in this case should be 2 1/4" (57mm)) Magnet Height - should normally be 20mm.. this one would be 15 or 17) Do let me know after u buy it, test it, blow it & then break it! Magnet Grade - Who knew about this one? (magnets come in different grades / strengths - Y20, Y25, Y30, Y35, Y40.. any guesses which one this would have??... WRONG !!.. due to popular demand.. they created a new grade - Y15!! WEIGHT: 5.5LBS (this stamped steel basket, thin t-yoke & washer - thicker ones are not required in Y15!) any takers? happy listening!! |
#9 |
This is my favorite part of the post...
THIS IS A MULTI ITEM LISTING EACH QTY OF 1 IS FOR 1 DSW10 10" SUBWOOFER YOU MUST PURCHASE 2 FOR A PAIR glad they clarified that issue... wouldn't want any confusion as to what a pair is....
"...His brain is squirming like a toad..." Jim Morrison |
#10 | |
Sorry if my post struck anybody as insulting, I didn't mean to. It was meant as a joke... The driver I referred to was a 10" woofer that appeared to ha a magnet only half the size it appeared to have because they fixed a plastic "container" over the magnet. I used them in my first DIYed speakers and was very disappointed when I discovered it.. I actually had good results with cheap woofers, many times supplied without thiele parameters. There are any shops that will measure them for you, a shop in my neighborhood does it for 15 EUR. That way at least you know what you're working with.... I don't need woofers, but anyone who buys them would be very helpful to post the parameters after measurement....
| cheap ebay dac's | valo | Digital Source | 1 | 11th December 2008 09:57 PM |
| Cheap finish for my cheap subwoofer? | mazeroth | Subwoofers | 19 | 26th July 2004 01:47 PM |
| Page generated in 0.10918 seconds (81.42% PHP - 18.58% MySQL) with 10 queries |
