Old 4th November 2006, 03:19 AM   #1
fergs1 is offline fergs1  Australia
Default Dayton IB 385. Any good in OB dipole/ripolel?
Greeting Ladies and gentlemen, just wwondering has anyone had first hand experience with the Dayton 15" IB 385 driver in ob dipole or ripole configurations and how do they stack up. Any comments most welcome cheers fergs
Old 4th November 2006, 04:02 AM   #2
Default no first hand experience...
The numbers look ok, however the first consideration is that of driver noise off the back side of the unit when playing 20 Hz. The driver needs to run silent or close to silent when running low frequency in free air conditions. Once you can establish the amount of noise there is you can try it out if it passes the test. This driver is probably a little on the hi side of Qts for a Ripole and a little lo for OB but close enough to work in either design. My guess is that an OB would be your best first choice. Hopefully you will hear from those who own this driver and you can find out more from them. Regards Moray James.
moray james
Old 4th November 2006, 08:08 PM   #3
I have two of these for stereo subs (only one built so far) and I am quite impressed with the low end extension of these.
The one is being use as my sub w/o eq. and is in a 22" U-frame, no fill and still needs to be braced. I was curious how much panel flex there would be in a U-frame so I left it as 3/4" mdf for testing (1.5"baffle-17"X17"). FYI, OB/Dipole may behave as a velocity source in a room, but the box experiences very high pressures and the panel vibrations are easily visible from 3-4 ft away.
So with that build info and with the fact that it is just placed in the room and no experimenting has been done to find the best spot for it here is the graph using a Radio shack meter and manual calibration at about 2m:
HPSA1000-R for Dayton HF15 midbass/dipole/line array thadman Solid State 1 11th January 2007 06:27 PM
HPSA1000-R for Dayton HF15 midbass/dipole/line array thadman Subwoofers 0 11th January 2007 05:50 PM
Any current dayton RS dipole project posted? sqlkev Multi-Way 24 4th February 2006 06:35 AM
How much power for dipole Dayton RS12 HiFis? mazeroth Multi-Way 3 9th December 2005 01:31 PM
Is the Dayton 5.1 a good HT system? AJ Bertelson Multi-Way 0 9th May 2004 01:18 AM
Page generated in 0.08323 seconds (68.17% PHP - 31.83% MySQL) with 11 queries
