Old 2nd November 2006, 09:20 PM   #11
ScottG is offline ScottG  United States
Originally posted by wingman
SLS 8" ?
Try it out
..good catch - hadn't seen that before.
http://www.tymphany.com/datasheet/printview.php?id=36
perspective is everything
Old 2nd November 2006, 09:28 PM   #12
Speakerholic
Cal Weldon's Avatar
Scott, You might have a point about the build quality of the MCM. I wonder if the Xmax rating is two way?
I have the TB 740C's and find them to be a good little workhorse. It's the only one of the group I've heard, but have no hesitation in recommending it.
What does the Peerless cost?
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 2nd November 2006, 09:35 PM   #13
I wondered about that myself..
Old 2nd November 2006, 10:00 PM   #14
AKN is offline AKN  Sweden
Enjoy good sound
AKN's Avatar
Datasheet for MCM says VC hight 24mm and gap hight 8mm so we have approx 16mm P-P or two way Xmax.
/ Anders
Old 2nd November 2006, 11:07 PM   #15
..missed that question originally.. sorry:
http://www.madisound.com/cgi-bin/ind...17753&pid=2164
Old 7th November 2006, 02:23 PM   #16
The TB w8-740C and the MCM driver referenced here are the two that are used in Bill Fitzmaurices small tubas, and I'm fairly certain that it was determined that the MCM xmax val was two-way. Anecdotal feedback on the two drivers was that the TB has significantly higher percieved quality, although I'm not sure on sound.
With the TB units, there is no need to go isobarik. I just threw together a sample at 4 ft^3 with 6 drivers and you can get down to about 30hz. With 6 units, you have tons of excursion to play with, although if you're looking for true 20Hz extension it may be tough.
If you have a decent EQ available, it's not even obvious that vented would be the way to go. Six of the TB's sealed in 3 ft^3 with appropriate EQ will do 105dB @20Hz, and that's before you pair them up or account for room gain.
Old 2nd December 2006, 06:55 AM   #17
Patrick Bateman's Avatar
Originally posted by ScottG
This should be in the subwoofer forum.. however,
for that small a volume (even with vas halved via isobarik loading), you'll likely want something with a low vas and high excursion (..considering effectivly 6 drivers per cabinet).
From least to most expensive:
http://www.mcminone.com/product.asp?...5Fid=55%2D2421
http://www.ascendantaudio.com/assassin8specs.html
http://www.tcsounds.com/tc1000.htm
I've published a box design for the first one. I'm using two of them in my car right now. As you add additional units, the respone flattens out nicely. You could make 12 of them for about $500-$600.
http://www.carsound.com/forum/showth...2&goto=newpost
Old 1st January 2007, 09:07 PM   #18
mateo88 is offline mateo88  United States
Patrick, can you post plans of your finished sub? It looks very interesting.
isobarik sub using peerless drivers busterno1 Subwoofers 6 18th September 2011 01:45 PM
Compound Isobarik, Drivers in series vs // pheonix358 Multi-Way 14 29th December 2008 11:58 PM
Driver for Isobarik use johngalt47 Subwoofers 9 26th January 2008 02:49 PM
How close can drivers be to each other in isobarik box busterno1 Subwoofers 1 19th October 2003 06:00 AM
Passive Radiator system with 2x10 inch and 1x15 inch Lach O'Sullivan Multi-Way 3 13th September 2003 03:29 PM
Page generated in 0.10253 seconds (76.43% PHP - 23.57% MySQL) with 10 queries
