Hi all,
I want to built a vented box with Sony XS-L102P5S driver. I know its an auto subwoofer but i will use that driver because i already have that one. The thiele parameters are; Qts:0,41 Vas: 52lt. Fs:26,6Hz Xmax: 62mm Qms:8,4 Qes:0,43 SPL: 89dB Diam:250mm (outer) As i calculated i will make a 55lt. box and will put two 50mm x 280mm ports on it. With this box i can get 25,6Hz F3 (WinISD says). I plan to built box as a cube (41x41x41 cm). But at this point i have some questions; - Does cube design ok for that project? Because WinISD says 42x65x26cm is optimum for 55lt effective volume! Does it make difference if i make it on cube style? - I cannot use one port because of its lenght (with 100mm port it will take 570mm!) Alternatively i will use two 50mm ports and 280mm each. And vent mach will stay 0,09. Do you think its ok? Or should i use one large and long port? - For that design; should i place the driver the bottom side (of course will put the distances to bottom side) Or should i put the driver front side? Does that two way make different results? Ot you can advice a better installation methode? Thanks a lot for your recomendations in advance. Best regards, Özgür. |
#2 |
Any idea?
#3 |
A cube shape is fine, standing waves aren't an issue at your target frequency with a box of this size.
Ports don' t have to be straight, use the larger port and use bends to fit it in the enclosure, don't forget to allow for the volume the port takes up in the box. I try and avoid mounting subs facing up or down because of the potential for cone sag. |
#4 |
Thank you volenti. That will be very usefull..
| Sony Str-D311 question | Kirk64 | Solid State | 2 | 30th April 2012 05:53 PM |
| Question about Sony TA-1055 | jonjonjonjon | Solid State | 3 | 28th September 2007 01:20 AM |
| Sony 557 ESD question | Bernhard | Digital Source | 1 | 25th October 2006 01:13 PM |
| Sony speaker upgrade question. | type | Multi-Way | 3 | 27th February 2006 04:55 PM |
| Page generated in 0.07430 seconds (72.92% PHP - 27.08% MySQL) with 10 queries |
