Which woofer to be made into a subwoofer would be a better match for an Usher 2 way with an 8945 woofer
12 inch Kef B300 or 8 inch Usher 8955
Dont have the specs for the Kef b300, but I think it goes down to 35 hz
the Usher Specifications: *Power handling: 80 watts RMS/90 watts max *VCdia: 1-5/8" *Le: .50 mH *Impedance: 8 ohms *Re: 5.7 ohms *Frequency range: 25-7,000 Hz *Fs: 25 Hz *SPL: 87 dB 2.83V/1m *Vas: 4.70 cu. ft. *Qms: 2.00 *Qes: .38 *Qts: .32 *Xmax: 6.0mm *Dimensions: A: 8-3/4", B: 7-3/4", C: 3-5/8".
Neither is a subwoofer.
The following is from arguably the best overall commercial subwoofer specialist:
http://www.velodyne.com/velodyne/tech/faqanswer.aspx?ID=12&sid=416v328k
