Old 24th October 2006, 07:25 PM   #1
Oborous is offline Oborous  Canada
Default How linear is Cms for a high-excursion subwoofer?
Hmm, seems I'm returning to Cms questions again,
I was reading: Active Compensation of Transducer Nonlinearities And came across Slide 32 on page 12.
I got the link from:Laser Instead of an Accelerometer? Is it possible?
XBL² technology seems to give a very flat BL curve, and excellent inductance curves. (See Tumult BL & Inductance Curves ). LMS also, at least via words, seems to indicate that the techonology could also give excellent BL curves (See TC Sounds LMS Technology )
I'm just wondering, is there a box configuration, or some tweak, that could 'linearize' Cms value for a subwoofer? If the first and third issue, according to Kippel, can be overcome with motor design, what can be done about Cms?
Old 24th October 2006, 09:55 PM   #2
ScottG is offline ScottG  United States
Default Re: How linear is Cms for a high-excursion subwoofer?
Nice paper link - thanks!
http://72.14.209.104/search?q=cache:...s&ct=clnk&cd=1
perspective is everything
Old 25th October 2006, 06:03 PM   #3
A box configuration, no not possible. Although a woofer in a small sealed box can utilize the pressure inside to override the effects of an imperfect suspension. By this I mean the distortion generated by the air pressure pushing on the cone area has way more effect than cms non-linearities. Of course this is just masking the problem with another.
"Some tweak" yeah, if you do alot of testing you can create algorithms to counteract nonlinearities in both BL and cms, this would be done by ramping up or down the signal going to the woofer's amp in a manner that would cancel any nonlinearites. Extremely difficult and I would bet it would be fairly expensive, this is why those who want accurate bass use low excursion woofers and lots of them to get spl and extension.
High excursion introduces alot of problems in the design stage overcoming them usually leads to an expensive woofer. So it can be cheaper to buy many lesser woofers, think one 18" tumult ($700) vs. 8 dayton 15"(~$700). Which would you rather have?
Old 25th October 2006, 09:06 PM   #4
Ron E is offline Ron E  United States
Ron E's Avatar
Actually the air spring is much more linear than the suspension and the nonlinearity of air can be neglected if the woofer Vd = Sd*Xmax is less than 10% of the box volume. The linearizing capability of the air volume stiffness, if greater than the suspension stiffness, is the origin of the term "acoustic suspension". So the text in the first paragraph above starting with "By this..." is incorrect.
"Algorithms to counteract nonlinearities" is kinda vague.... All you need to do is apply negative feedback
IF you have a really linear suspension, any BL assymetry or nonlinearity will cause dynamic offset problems - which are much more severe than Cms -caused distortion. Dynamic offset is also known as oil-canning.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
Old 25th October 2006, 11:03 PM   #5
forr is offline forr  France
forr's Avatar
---Actually the air spring is much more linear than the suspension and the nonlinearity of air can be neglected if the woofer Vd = Sd*Xmax is less than 10% of the box volume.---
Linkwitz gives a formula for calculating the H2 distorsion generated by the air non-linearity in a closed box.
A woofer has second and third order non-linearities. I am not aware of a third order non-linearity for the air. If the internal volume of the box, Vab, is smaller than the Vas of the speaker mounted in it, the compliance of the air will dominate in the response of the system. So there should be less third harmonic when the unit is enclosed than when used on a pannel.
Old 25th October 2006, 11:55 PM   #6
http://www.linkwitzlab.com/thor-design.htm
http://www.musicanddesign.com/driver_box.html
Note that you can alter driver/system compliance with the "box" (or driver depending on how you look at it) - even one with a relativly small volume.
Consider a box within a box where the interior box is a very small chamber (cavity-coupled to the driver) and the walls are lossy (..perhaps made of fiberglass paneling with some small perforations). I wouldn't think that it would make driver compliance anymore linear though (..actually I think it might do the opposite).
Old 26th October 2006, 01:54 AM   #7
Actually I was referring to the much higher restoring force of the acoustic suspension dominating the behavior of the total suspension. If you have two springs in parallel one being the suspension and the other being the air the one with the higher spring constant will dictate the behavior of the speaker the most, apparently worded poorly the first time.
Leave it to an M.E. describe negative feedback in the stupid way that I did.
Old 26th October 2006, 05:27 PM   #8
...Extremely difficult and I would bet it would be fairly expensive, this is why those who want accurate bass use low excursion woofers and lots of them to get spl and extension.
Hiya,
Excellent posts everyone, I'm learning alot...
I've come to the same conclusion, that for subwoofers, you're probably better off with even numbers (and multiples) of subwoofers, and probably smaller subwoofers to generate a given low frequency SPL. But, if I can't afford the real estate of that many subs, what are my options.... so I'm looking into what I can do to get as good of sound quality as possible at a reasonable SPL, in a small package without comprimizing anything except for SPL.
I am wondering about a box for a high-excursion subwoofer, operating it only within the BL-linear region i.e. utilize a Adire Tumult ~24mm X-max rather than their listed X-max; which I'm thinking I can easily do by limiting the available power.... basically utilize a 1,000 watt amp instead of the ~~1,600-1,800 watts that S. Linkwitz's handy spreadsheets indicate are neccesary to utilize a full 33mm of X-max (Yes, this still is crazy amount of power, considering I'm using 25 watts of chip amp power, or looking at 8 watts of SET power).
I'm trying to figure out how to have a linear Cms value, would limiting the Xmax also limit the non-linearities due to extreme excursion on the suspension?? I'm assuming maximum non-linearity is present at maximum excurision.
Any suggestions on how to measure Cms non-linearities for a non-engineer? I do have engineer friends, so might be able to utilize some more professional equipment.
Old 26th October 2006, 05:31 PM   #9
Svante is offline Svante  Sweden
Svante's Avatar
The special amplifier of ACE-bass (Audio Pro) has the effect of linearising Cms, or rather having an artificial C dominating over Cms, such that the total C becomes linearised.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 26th October 2006, 05:43 PM   #10
Could you provide reference for that? I think by reading the whole article of where that came from, I really could learn alot. (Currently trying to purchase more books, as reading is alot easier to do than get shop time to build proto-types... so if you have suggestions for books, please pass them along).
I'm interpreting this as: In a smaller box, the internal air is a stiffer spring, and so would dominate the 'parallel spring' analogy. Where as when the air is not that 'springy', suspension would dominate (which could occur in very large boxes, or ported boxes).
Which, would seem to be supported that Fb is much larger than F3 for smaller boxes, than larger boxes... as the air suspension is much stiffer, which makes it more difficult to resonate at lower frequencies...
Which... also seems to indicate, that in small boxes, the thermal expansion of the air could really cause problems if I'm dissapating alot of energy into heat.... hmm, non-linear response over a long period of time due to heating effects... something to think about.
Over excursion protection for subwoofer Buzzy Parts 14 15th April 2010 01:49 AM
Over excursion protection for subwoofer Buzzy Subwoofers 12 19th June 2009 06:19 AM
where to buy 8" high excursion sub in EU ? wingman Subwoofers 25 12th June 2004 10:18 PM
Subwoofer Excursion and ports. Lach O'Sullivan Subwoofers 5 29th September 2003 11:41 AM
Page generated in 0.14312 seconds (82.66% PHP - 17.34% MySQL) with 10 queries
