Hi everyone--
I just got a 500W BASH plate amp from Parts Express (#300-752), and the bottom of the spec sheet that came with it says: "Note: Do not attempt to connect amplifier to test equipment. Doing so my result in a hazardous situation." This warning isn't on the PDF version that's on PE's website. Is this just a standard CYA type warning, or is it because the output is bridged, and the "-" speaker lead is not a ground-referenced signal? I did measure a ~1V DC voltage between the "-" and the shell of the RCA inputs. I'd like to do some testing and experimenting with it and Speaker Workshop, but I don't want to blow up my soundcard. Any suggestions for the best way to do what I want to do? Thanks-- Greg |
#2 |
At least chances are big that the "Bridged Amplifier Switching Hybrid" is actually a bridge topology.
Regards Charles |
| FS: BASH plate amp 500W | dsrviola | Swap Meet | 1 | 26th December 2007 09:53 PM |
| Boost in BASH plate amps.. | JandG | Multi-Way | 0 | 9th March 2007 11:54 PM |
| PE BASH 500W Plate Amp | Viking552 | Subwoofers | 9 | 10th January 2007 06:56 AM |
| Is the Bash 300 plate amp airtight? | preiter | Subwoofers | 1 | 17th July 2006 05:50 PM |
| BASH Plate Amp | CARTRulz | Subwoofers | 6 | 29th June 2006 05:43 AM |
| Page generated in 0.05701 seconds (76.46% PHP - 23.54% MySQL) with 10 queries |
