I'm new to this whole car audio thing, I just need to know if a mono amp can run 2 subs or if it only runs 1. This may be a stupid question but i just need to know what to buy. thanks for any help
#2 |
Did it Himself
The number of subs is irrelevant, what matters is the impedance load on the amp.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#3 |
most car amps can drive a 4ohm load and some even lower. Select your sub to suit your amp. Car amps often perform quite badly on the lowest impedance in the specification. It sometimes helps the sound quality to use a driver with twice the impedance quoted as the minimum. This reduces the power that comes from the amp, but this is often compensated by improved sensitivity of the higher impedance driver. i.e. using an 8ohm driver off a 4ohm amp might be just as loud and WILL sound cleaner. BTW. be helpfull in your title!
regards Andrew T. |
| Page generated in 0.06717 seconds (68.69% PHP - 31.31% MySQL) with 9 queries |
