Old 22nd October 2006, 10:58 PM   #1
Default side firing sub
i'm about to build an mtm with a side firing sub(sealed).it's a 12 inch.i want to keep the box skinny.at the present size the woofer will have only have 4.5 " of space behind the magnate.is this enough room? or does space behind the woofer matter in a sealed box?
Old 23rd October 2006, 08:59 AM   #2
Volenti is offline Volenti  Australia
That's plenty of clearance behind the magnet, if it's a pole vented sub you really only need the same clearance as the diameter of the vent.
Old 23rd October 2006, 06:35 PM   #3
I can't tell from your brief, but the woofer must be in a separate chamber from any other unsealed drivers.
regards Andrew T.
Down firing vs side firing? Tee-Bruce Subwoofers 36 26th August 2009 06:32 AM
Woofer: side firing pair vs front firing? tcpip Multi-Way 13 9th September 2005 02:13 PM
side firing sub chainenoble Subwoofers 2 29th August 2005 03:29 AM
Side firing woofers in 3-way Mos Fetish Multi-Way 7 3rd August 2003 01:57 PM
side firing woofers ogp Multi-Way 2 9th January 2002 01:44 AM
Page generated in 0.05518 seconds (80.13% PHP - 19.87% MySQL) with 10 queries
