Old 22nd October 2006, 02:43 PM   #1
venki is offline venki  India
Lightbulb A coffee table idea.
Long time since I posted anything....my sub story so far
Driver : Bolton 8".
Box: 4th Order
I have been trying to find possible 4th order box designs (Qts about .6 I know this is too high but already brought this )
First attempt...
a conventional 4th order with a 3 inch port.
Result: I could hear the chuffing clearly
Second attempt....
Again the same box now with 4" ports.
Result: this time it was better but on high volumes the chuffing was there.
Then while browsing the net I came across the "Wicked one" (Decware) and decided to make something similar (though the result is nothing from similar ). I didn’t go for the conventional horn design since my woodworking skills where not so great. I altered this box to have a conical port. The sound improved dramatically!!! Now the only noise I hear now is of the speakers when it is driven to its limit (the speaker is only 50 W and begins to degrade even before that ). Anyway the whole idea was to see if the thing works. I decided on the initial throat area (~ to 4" PVC pipe) and calculated the outer area (mouth) based on the length of the box (approx 50 cm).
A variation of this idea would be to have a polygon box having the port starting from the center and growing outwards. This way we can achieve two things
1. Reduce the length of the port
2. Making the box omni directional.
Sorry if I confused you guys...just that it hard for me to put the idea into words.. to make it less confusing I have attached the box plan made in google sketchup...
This is just any idea and I am not sure about the complexities in design and acoustic properties. Just wanted have a discussion on this so that I can improve on my design
Venki.
Old 22nd October 2006, 02:44 PM   #2
Default Another view...
Another view
Old 22nd October 2006, 02:54 PM   #3
Default My existing sub
Pic 1
Old 22nd October 2006, 02:55 PM   #4
Pic 2
Old 22nd May 2009, 06:25 AM   #5
Default Need Bolton's Dealer address
HI,
Can you please provide me bolton's contact Info? I am crazly searching for. Previously & mumbai Auhaja radios stocked it, but its closed now.
Old 22nd May 2009, 08:09 PM   #6
chris661's Avatar
Might it be an idea to make this into a ported down-firing subwoofer instead??
And I like the idea of making it into a coffee table - WAF rating much higher...
I think it would redice the chuffing. Have you tried rounding off the port, like on http://www.dansdata.com/images/speak...electro440.jpg
Chris
"Throwing parts at a failure is like throwing sponges at a rainstorm." - Enzo
My setup: http://www.diyaudio.com/forums/multi...tang-band.html
sub-woofer "coffee table" zafira1981 Subwoofers 5 5th January 2008 12:52 PM
Anyone have a Decware WO32 coffee table sub? rcavictim Subwoofers 4 4th July 2007 10:22 PM
coffee table open baffle?? mpmarino Subwoofers 10 7th September 2006 03:50 AM
Help needed for high power coffee table subwoofer project Sixthofmay Subwoofers 26 6th July 2004 12:31 AM
Page generated in 0.09509 seconds (73.40% PHP - 26.60% MySQL) with 11 queries
