Downfiring sub, how much space underneath? - Page 2 - diyAudio
Old 19th October 2006, 06:52 PM   #11
Ric;
I built the sub in a rather large "endtable" enclosure some time ago and it is truly amazing, however, changes in the configuration of the room force me to downsize the enclosure to a simple 17" cube and place it in a corner. Can't figure out how to send a picture to this blessed forum, but there are shots of it on the Rythmic website.
I had considered downfiring at the start but concerns about distortion from the floor altered my plan. Having listened to the unit for some time I do not believe that this will be an issue and if it is I'll cross that bridge when I get there. Should begin building in a month or so.
Pete
Old 19th October 2006, 07:24 PM   #12
I think I know which one you mean, looks nice
Sounds awesome doesn't it
I'm in debate at the moment as to if I should rebuild my DS12 into the new box or order the 15" driver and knock my house down
Thanks to everyone that replied
Old 19th October 2006, 08:51 PM   #13
Ric:
Go for it!-------"Knock the House!"
Good luck,
Pete
Old 20th October 2006, 07:12 AM   #14
Collo is offline Collo  Australia
Collo's Avatar
Send a message via MSN to Collo
I'm currently working on some software for sonosubs.
The guidleine I'm intending to use for the gap between the bottom endcap and the floorplate is:
"The air leaving the front of the driver should not encounter a cross-sectional area smaller than the area of the cone itself"
The green area in the attached drawing should be equal or greater than Sd of the driver.
An approximation using nominal diameter is:
An 08 inch driver needs 1-9/16 inch gap
A 10 inch driver needs 1-15/16 inch gap
A 12 inch driver needs 2-3/8 inch gap
A 15 inch driver needs 3 inch gap
An 18 inch driver needs 3-9/16 gap gap
Comments??
File Type: gif breathing-room.gif (693 Bytes, 193 views)
Ports rule!
Old 20th October 2006, 08:15 AM   #15
What would happen if that height was doubled or trippled?
Old 20th October 2006, 11:39 AM   #16
Collo's Avatar
Those figures are what I guess are the absolute minimum spacing to be used.
Going to double or tripple those amounts won't hurt your design apart from the sub being taller than it really needs to be.
Ports rule!
Old 21st October 2006, 10:36 PM   #17
I had a similar question last year and emailed rythmikaudio directly with it. He responded immediately with a very thorough answer.
Old 22nd October 2006, 02:26 AM   #18
Collo's Avatar
and the answer was.....?
Ports rule!
Old 22nd October 2006, 04:07 AM   #19
I was interested in mounting the driver in one of his kits downward.
He said it was perfectly ok. It's been over a year since that. I'm 99 percent certain that this is what he said and 75 percent certain that you and I are describing exactly the same driver, enclosure type, linkwitz transform or servo, etc. That's why I'd suggest you email him with your exact question. Only reason why I suggested it to you is to assure you that he responded to me promply and fully. Others on this board have had similar correspondence with him. I forgot his name, I think it was Brian.
Good luck.
Old 22nd October 2006, 10:22 PM   #20
Collo's Avatar
Will chase up. Thanks
Ports rule!
downfiring sub formula blue934 Subwoofers 2 8th June 2007 02:26 AM
Titanic MK3 downfiring sub Renron Subwoofers 6 27th March 2007 03:51 PM
Problem with mouting choke underneath chassis? G Tubes / Valves 4 2nd May 2004 10:38 PM
Upfiring or Downfiring? masterp2 Subwoofers 2 11th March 2002 10:58 PM
Copyright 1999-2017 diyAudio
