Bass driver Vas mods? - Page 2 - diyAudio
Old 17th October 2006, 01:16 AM   #11
Default Andrew look at the Peerless SLS 315...
Have a look at the Peerless SLS 315 which you can probably find for about $80.00 CND on your side of the pond. This is just about made to order for a "W" dipole cabinet with very low rear noise. Regards Moray James.
http://www.bmm-electronics.com/Produ...roduct_ID=4296
moray james
Old 17th October 2006, 10:09 PM   #12
georgehifi's Avatar
Send a message via MSN to georgehifi
Check out the ACI SV-12
http://www.subwoofers.cc/HomeAud/HDrivers/SV12b.asp
Out of production now, but taken up by Meniscus Audio SW-1284 same speaker but they have lowered the VAS from 250lt to 170lt this could be ok.
http://www.meniscusaudio.com/speakercomponents/
Here's a pic of it, I have it working from 25hz to 160hz in 85lt stuffed sealed, sounds very good.
Avatar : Production Lightspeed Attenuator
www.lightspeedattenuator.com
Old 17th October 2006, 10:10 PM   #13
georgehifi's Avatar
And another,
Old 17th October 2006, 10:11 PM   #14
georgehifi's Avatar
One more.
Old 17th October 2006, 10:50 PM   #15
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
I question whether low Vas is something desirable as a driver spec. Sure it reduces the box size for a target Q, but otherwise I don't believe it's something we want. It is a component of CMS, mechanical compliance (the higher the Vas, the higher the compliance), and compliance is a good thing. It is also a component of RMS, mechanical resistance (the higher the Vas, the lower the resistance), and RMS is a bad thing. To me it boils down to wanting a driver's operation to be controlled my its motor, not it's suspension. Wouldn't a perfect world driver have no suspension at all and unlimited motor control ?
Everyone has a photographic memory. It's just that most are out of film.
Old 18th October 2006, 03:26 AM   #16
Ron E is offline Ron E  United States
Ron E's Avatar
Not to sound as if I am arguing semantics, but saying Vas is a component of Cms is like saying that wavelength is a component of the speed of sound.
There is not necessarily a correlation between Rms and Vas, either.
Whether the damping is electrical or mechanical is immaterial.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Old 18th October 2006, 04:10 AM   #17
Ron,
That's just semantics. There's a direct correlation between Vas and CMS, and an inverse relationship between Vas and RMS.
I must take exception to your statement regarding the source of damping, because I've yet to hear a low Qms (high mechanical damping) driver that sounds really good, and I can say the same for drivers with low Vas in relation to their size. IME stiff suspension corresponds directly to poor sound.
Old 18th October 2006, 07:42 AM   #18
am I right in thinking that all PA type drivers are optimised for high SPL and the direct result of this optimisation is low Vas (& high Fs)?
If that hypothesis is correct then it supports John's contention that low Vas =poor sound quality.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th October 2006, 10:08 AM   #19
bigwill is offline bigwill  United Kingdom
Oh god I wish you could get these in the UK I'd put two per side on an open baffle. The best thing you can get for that price here is a "tiny" 15" woofer with a paltry 4mm xmax only useful in OB, compared to that 18" driver with 12mm that can even go in a ported box!
Old 18th October 2006, 11:18 AM   #20
Hi Bigwill,
you think BIG!
Each 18inch with 12mm Xmax is equivalent to about 4 of my 15inch Tannoys.
You want a pair per side.
That is equivalent to 16off 15inch drivers in one room.
How long will the room last!
regards Andrew T.
PA bass driver a007udio Multi-Way 6 31st May 2006 11:06 AM
Burgera Bass Driver LightwaveDude Instruments and Amps 17 15th March 2006 02:29 AM
bass amp and driver leander Solid State 4 3rd November 2005 12:53 PM
Getting the most bass out of a driver BAM Multi-Way 7 5th September 2002 04:43 AM
Looking for very good bass driver slicemaster101 Subwoofers 31 2nd September 2002 06:52 AM
Copyright 1999-2017 diyAudio
