Old 15th October 2006, 04:27 AM   #1
Default Generic Sub Crossover Suggestions?
I tried finding the specs for the Martin Logan subwoofers used in the Descent, but no luck. I even called the company and of course, they said all the info was proprietary.
Anyway, I have already built an amp (although it is only pushing around 100 watts) and now, I am just looking to build a crossover that will cut off around 80 hz.
Since I dont have the speaker specs, I just need a generic crossover to start with and then I can tune it by ear. Since I am new to crossovers, I am not sure which values would be on the safer side of experimentation.
Some ideas or even schematics would be great...
Thanks,
Dominick
A real amateur enthusiast!
Old 15th October 2006, 09:42 PM   #2
Bump
Some help please!
Dominick
Old 15th October 2006, 10:21 PM   #3
mikee55 is offline mikee55  United Kingdom
mikee55's Avatar
Default Hello
Hi there, Take it you asked the Google, and searched as hard as you can? Its not easy, is it?
The Elliott Sound Products site has shed loads of info on all things hi-fi.Did you go there? He's got a great article on xovers.
Others, chime in please....
http://sound.westhost.com/index.html
If it don't work, I'll fix it in the mix! Or visit http://lsdp.proboards.com/index.cgi
Old 15th October 2006, 10:38 PM   #4
Speakerholic
Cal Weldon's Avatar
If you want an 80Hz XO can you not build that into the amp?
The size of the components needed for a 24 dB passive will be cost prohibitive.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 16th October 2006, 02:17 AM   #5
Cost prohibitive--how so? I cant imagine costing more than $50, but I would be willing to spend up to $100.
Dominick
Old 16th October 2006, 02:28 AM   #6
OK,
Check out what I found. This calulator works pretty good I think. I wanted to see what others thought.
Anyway, I am not actually using a tweeter. I am trying to build a filter for just a sub. Would the adjustment in the case be as easy as removing the tweeter from the digragm? Or would that change the values of the resistor and capacitor?
http://www.lalena.com/audio/calculator/xover/
Thanks,
Dominick
Old 16th October 2006, 02:58 AM   #7
If I wire these in series:
http://www.partsexpress.com/pe/showd...number=255-840
Will I effectively arrive at a 24mH Inductor?
Dominick
By the way, I appreciate the help offered by my fellow DIYer's!
Old 16th October 2006, 03:58 AM   #8
Ken L is offline Ken L  United States
Default Re: Generic Sub Crossover Suggestions?
To get it right, will take quite a bit of time money and energy.
IMHO, Cal is right in trying to point you in a different direction
80hz is pretty low and hard to hit with accuracy, gonna be expensive and big,
Most people crossing that low use some form of passive, line level crossing and bi-amp.
You might do well to consider that approach.
Marchand, I know offers passive line-level crossovers - should be some where around $100 ro $150 IIRC.
Generally, it has been my experience that when you get beneath 100 hz, the steeper the slopes the better.
No longer powered by Linux - not enough apps and cross platform integration - but maybe one day
Old 16th October 2006, 08:02 AM   #9
pinkmouse's Avatar
Have a look at in car active crossovers. They are pretty cheap, and well sound much better than anything passive you could make up.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 16th October 2006, 11:38 AM   #10
Thanks guys...I will have a look!
Dominick
low-pass crossover suggestions Telstar Multi-Way 24 18th November 2008 11:34 AM
Crossover suggestions? trunkmonkey Multi-Way 12 22nd April 2006 07:00 PM
Suggestions on my crossover design? JoeyDD Multi-Way 11 11th December 2005 02:05 PM
Generic active filter / crossover... board... thingie... JohnR Parts 5 14th October 2002 10:13 PM
Page generated in 0.10320 seconds (77.56% PHP - 22.44% MySQL) with 10 queries
