Old 28th September 2006, 08:50 PM   #1
bluegti is offline bluegti  United States
Default Dual Driver Subs?
First off... I really have no clue how to design my own subwoofer, so what I want to build may not make any sense. I won't be offended if you tell me it doesn't make sense, but I would appreciate a shove in the right direction.
I want to build 2 subwoofers that will act as the woofer/subwoofer for some full-range monitors. I want the subwoofers to act as stands for the monitors so it almost looks like one speaker, even though they would be 2 separate enclosures.
I'm thinking of using two smaller drivers instead of one larger one - For aesthetic reasons (I know, shouldn't matter, but it does) I want the monitor and sub to be the same widths. I would like the frequency response to go from below 40hz to 120hz.
Do you think I could use two 6" or 8" forward facing drivers in a tall thin enclosure with an off-the-shelf subwoofer amp to do this? Any recommended components? Any recommended designs? I haven't found any with dual drivers.
Old 28th September 2006, 09:09 PM   #2
Lothar34's Avatar
Send a message via AIM to Lothar34
You can put them in two separate stacked enclosures. Any particular reason you want to do that?
I would use 8" though if you want to get below 40Hz. What kind of power handling were you looking for? You want one amp to run both?
Old 28th September 2006, 09:27 PM   #3
I don't think I would want to have 2 enclosures stacked... that would make 3 stacked including the monitor. It might be a little unstable.
Each sub would have its own amp. I would have one amp for both drivers. I figured I could run two 16ohm drivers in parallel for a 8ohm load, or two 4 ohm drivers in series for a 8 ohm load - something like that. I've read a little about dual voice coil drivers that give you flexibility for the impedence, but again I know nothing about desiging subs, so I'm making this stuff up.
Old 28th September 2006, 09:51 PM   #4
Lothar34's Avatar
I meant the monitor stacked on the sub, not the two subs stacked. But now I think I'm confused. Did you want one pair of drivers or two pairs of drivers? I was thinking you wanted one sub with one driver per side.
What's your budget and how much power did you want to push to them?
Old 29th September 2006, 12:15 PM   #5
RobWells's Avatar
If you want each stand to match the width of the monitors and use a decent sized driver, you can put the sub driver on the side of the stand, rather than the front.
Rob.
Old 29th September 2006, 07:03 PM   #6
Default You know what they say...
A picture's worth 1,000 words. The top box is the monitor, the bottom box is the subwoofer. I want to make two of these. Each sub would have its own amp. I'm think having the drivers face forward would be better since I want the bass to extend up to 120hz or so.
What do you think?
Old 29th September 2006, 07:16 PM   #7
Lothar34's Avatar
Old 29th September 2006, 08:09 PM   #8
I'd go for 8's over 6's or 6.5's. It's better to have too much and turn it down, than not have enough and be unable to turn it up.
That being said, I 2nd the idea of having a side firing woofer. I feel it helps clean up the face of your enclosure. It doesn't look so cluttered.
Old 29th September 2006, 09:52 PM   #9
dscline is offline dscline  United States
Default Re: You know what they say...
What do you think?
At that frequency, it won't make any difference. Playing 120hz test tones and some a/b testing with left/right speakers, you might be to tell which side of the room it's coming from, but simply having the driver rotated 90° isn't going to make any noticeable difference in real world use.
Old 29th September 2006, 10:27 PM   #10
RobWells's Avatar
Don't look bad for an 8:
http://www.partsexpress.com/pe/showd...number=295-545
Rob.
dual Voice coils on subs skooter Car Audio 9 15th September 2008 06:46 PM
question on my 4ohm subs / dual voicecoil Lifo Car Audio 3 13th January 2008 01:06 AM
6 X Dual 4ohm Subs LEESTER Car Audio 2 23rd February 2007 12:42 PM
First Project Completed - Dual 10" Subs 69stingray Subwoofers 8 21st July 2005 03:25 AM
Dual subs below 80Hz- what should I be hearing? darkmoebius Subwoofers 8 17th July 2005 04:38 AM
Page generated in 0.11285 seconds (77.23% PHP - 22.77% MySQL) with 11 queries
