Old 26th September 2006, 06:46 PM   #1
Default Driver for low volumes
Is there anything special I should be looking for in a driver to be used at low volume? I'm building a sub for the office at work so I need to keep the volume down.
Thanks,
-Ron
Old 26th September 2006, 07:18 PM   #2
Lothar34's Avatar
Send a message via AIM to Lothar34
I would think something fairly rigid with good control. Big voice coil, high Vas, high Qms and a low Xmax.
What size were you thinking about and what's your price range?
Old 26th September 2006, 09:56 PM   #3
I'm looking to go for something small, probably in the 8" range. I did have one thread going here but low volume wasn't answered.
Right now I've been thinking about going with the Tang Band W8-740C since I can fit this in a 5 liter box.
My only concern would be that it doesn't work well at low volumes.
Old 26th September 2006, 10:39 PM   #4
Lothar34's Avatar
I thought you were gonna get that Dayton?
Old 26th September 2006, 10:47 PM   #5
I had thought about it, and the Dayton does go a little lower but while the TB fit's in a 5 liter space I'd need 23 liters for the Dayton. I think that's to big for the space.
Old 26th September 2006, 10:49 PM   #6
Lothar34's Avatar
Here you go:
http://www.madisound.com/cgi-bin/ind...8.421&pid=1959
EDIT:
Well they recommend 15L for this one. Is that still too big?
Old 26th September 2006, 11:42 PM   #7
Lothar34's Avatar
Well that one is out of stock.
Either of these will be good too:
http://www.partsexpress.com/pe/showd...number=290-042
http://www.partsexpress.com/pe/showd...number=296-175
Did you need shielded or not?
Old 27th September 2006, 12:35 AM   #8
I don't need shielded since it will sit under my desk. The Audax requires to much space, even in a sealed unit. The Pioneer is better but still needs around 15 liters.
Maybe I'll build a couple of them to test things out.
Old 27th September 2006, 01:04 AM   #9
Lothar34's Avatar
I believe that's 15L with no stuffing. You can probably get away with 10L and some polyfil.
Old 27th September 2006, 02:26 AM   #10
Lothar34, thanks for the advice. Couple of questions. Not that I doubt you but why do I want a high Vas, high Qms and a low Xmax?
The Pioneer definitly wins the Vas and Xmax
2.440 ft cubed vs 1.130 ft cubed
2.88 mm vs 12.0 mm
But the Tangband wins the Qms
10.530 vs 4.170
I know I keep coming back to the Tangand but I love the idea of a 5 liter sub assuming it plays well at low volumes.
Cascading volumes on a 5C3 amp bereanbill Tubes / Valves 9 10th April 2009 12:02 AM
Chipamp shorting at high volumes. A Sanchez Chip Amps 27 18th September 2008 01:34 PM
lm3886 and differant volumes kanifee Chip Amps 22 9th July 2008 10:51 PM
Designing enclosure volumes Syncroniq Multi-Way 4 6th June 2008 11:09 AM
Driver distorts at high volumes.... eRiCdWoNg Multi-Way 5 2nd November 2003 11:22 PM
Page generated in 0.08305 seconds (87.82% PHP - 12.18% MySQL) with 10 queries
