Old 12th September 2006, 08:40 PM   #1
Henkjan is offline Henkjan  Netherlands
Henkjan's Avatar
Default TL sub with 2 TB69 woofs
some time ago I built this sub:
this was intended as a test project, to see how a TL built to the K+T recipe would sound, but I have it in use in my HT for almost half a year now, it realy sounds that good. total costs were ~100 euro.
I choose the 6x9 woof because it would enable a narrow sub that would fit under the sofa in the living. probably somewhere this year it will end up there I guess....
key figures: straight TL, cross section 110% of the total Sd, L=2.2m, woofers positioned at 1/3 and 1/5 of the line. almost without any stuffing, only a little bit at both ends of the line
simulated it in MLK's "section sheet":
Old 15th September 2006, 01:33 AM   #2
BAM is offline BAM
Send a message via AIM to BAM
Very nice. What Tang Band woofers were used? I figured it was only a matter of time before someone tried these in a Transmission Line -- since they bear a resemblance to the famous KEF B139. I have thought about doing the same thing with their 8"x10" woofers. Having a sub that you can fit in a narrow space doesn't hurt, either.
I found another pic of the front of this subwoofer, showing the front of the drivers.
http://album.zoom.nl/user/Henkjan/luidsprekers/983766
I also spy, with my little eye...
http://album.zoom.nl/user/Henkjan/luidsprekers/633471
Old 16th September 2006, 08:59 AM   #3
Henkjan's Avatar
I used the W69-1042.
It was a surprise to me how well these performed. I used the rule-of-thumb design from the german magazine Klang+Ton and then adjusted it a bit using MLK's MathCAD sections sheet. main change of that was that I left out almost all of the stuffing and a small increase in cross section.
I have not done any measurements yet, but by listening it feels like the will easily do 30Hz. (I measured my Peerless CB woof and that one does with a small boost from the amp 35Hz straight, and the TL sounds like it will go a bit lower (without boost))
Old 17th September 2006, 11:35 PM   #4
BAM is offline BAM
I think that this would be a good subwoofer for anyone who wants to hide their sub in a corner behind a piece of furniture. If I didn't already have something else in mind for my parents' home theater (they just bought their first HD set, and first new TV in 12 years), I'd probably build this. I'm thinking of experimenting with a daline enclosure for a Tang Band 5" ultra long-throw subwoofer driver for that particular use, but I like your use of unconventional drivers to suit your purpose.
Old 13th February 2009, 12:02 PM   #5
Henkjan's Avatar
I noticed the pix went 404 in my 1st post... so now as attachment
Old 13th February 2009, 12:08 PM   #6
Henkjan's Avatar
here's the sim. the dip around 200Hz should not be irl because the 2nd woofer at 1/5 of the line (cannot sim the 2 woofers design). and yes, the sub is in the living now, not under the sofa but under the TV
Woofs, mids, tweets, fullranges, coaxes (Seas, Tang Band, Fostex, Morel) audiokinesis Swap Meet 26 24th July 2011 07:34 PM
6.5" woven carbon mid woofs (6) johnmark Swap Meet 1 15th October 2008 12:07 AM
4" Seas long throw woofs, Motorola piezo compression drives, TangBand 2" widebands mr_ro_co Swap Meet 4 15th April 2008 01:16 AM
Line array for HT with built in powered woofs elambert Multi-Way 0 27th April 2005 01:44 PM
Page generated in 0.08675 seconds (74.21% PHP - 25.79% MySQL) with 11 queries
