Hi, i have an paradigm subwoofer, and i want to upgrade my system, i want to build my own subwoofer, wich driver recommends me? the Room size is 23x13 Feets.
i want to down to at least 20hz!. and i think that 12" will be ok. |
#2 | |
Banned
What size is you'r Paradigm ? whats the model ? Is that sub loud enough for you or you want more now ? |
#3 |
Paradigm PDR-10 is the model
- Single driver, bass reflex, high-velocity low-turbulence resistive port, built-in amplifier - 120 watts RMS / 360 watts Peak - 254-mm (10 in) carbon-fiber-reinforced composite cone, 38-mm (1-1/2 in) voice coil - 27 Hz (DIN)* - Cutoff Variable 50 Hz – 150 Hz - weight 12.5 kg / 28 lb each these are the specs of the subwoofer that i have right now. I want to sell it and build another with more power and maybe that go a little low (20hz). |
#4 |
Banned
I know all the paradigm Sub's. I'm a paradigm speaker fan.
Well you need to tell us if you need more bass or are you just looking to build something. Ie starting off with a sub. |
#5 |
well i want to improve the quality of my sub, thats all, i want to go more deep, i think that the paradigm dont down to 20hz.
and more power will be great too |
#6 |
As a minimum
Adire 12" (shiva for example) on large ported box. ~300w Plate amplifier Done! |
#7 |
and as a maximum?
#8 |
How long is a piece of string?
18 inches. 30mm one-way x-max to be exact. http://www.tcsounds.com/tc5200.htm
#9 |
damn thats amazing
its really too big for my room i need some small i read that scan speak 23w/4557t00 is good... |
#10 |
If you are looking for small enclosure size, look at the PEERLESS XLS or XXLS line:
http://www.tymphany.com/products_Peerless.html ANother option would be an Ascendant audio driver, which would probalby cost less than a PEERLESS driver, not sure about shipping to SA: http://www.ascendantaudio.com/assassin12specs.html In either case you will need adaquet amplification and be able to build the enclosure.
none |
| Pro Sound EV Subwoofer 133 db 1w/1m HOW TO BUILD? | jadenlinkletter | Subwoofers | 6 | 28th January 2005 07:55 PM |
| Build a subwoofer with these drivers? | mazeroth | Subwoofers | 7 | 30th August 2004 07:10 PM |
| Looking To Build SPL Subwoofer | Mista_Bishi | Car Audio | 12 | 13th May 2004 06:55 PM |
| I want to use a bad driver for a good subwoofer | red | Subwoofers | 18 | 27th December 2003 08:28 AM |
| how to build a subwoofer? | nicovdk | Subwoofers | 7 | 26th December 2002 02:11 AM |
| Page generated in 0.10054 seconds (78.37% PHP - 21.63% MySQL) with 10 queries |
