Sub integration
Sub integration
Old 12th September 2006, 12:39 PM   #21
JRKO is offline JRKO
JRKO's Avatar
Send a message via AIM to JRKO
Not too sure what you mean when you say line level bass boost.
Do you mean bumping it up before amplification?
If this is the case then I am stuck as I am using an integrated amp. I could always try some GRF type cabs (either corner loaded or the 5 foot tall rectangular ones)
I love the mid & highs the Tannoys provide
Or I could just make cabs optimised for mid frequencies from the driver and add a whumping great sub
If I'm not making noise, I'm making something to make noise
Old 12th September 2006, 04:38 PM   #22
R.I.P.
In my integrated amplifier I modded the feedback loop
of the power amplifier to boost low bass by up to to 8dB.
Very easy to do.
/sreten.
Old 12th September 2006, 04:44 PM   #23
JRKO's Avatar
The way you say it makes it sound really easy . . . . for an EE
I really would not be that confident about opening up my amp. First my wife will kill me if i break it, second although I have made some working gainclones I would be worried about making a crappy solder joint and blowing the thing up......it cost me a few pennies.
Old 12th September 2006, 07:09 PM   #24
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Sub integration
No need to open anything up, just build a little box with a boosting (high q) filter in.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Old 12th September 2006, 07:26 PM   #25
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
Sub integration Send a message via MSN to AKN
Hi!
Those modeling this speaker, isn't a passive filter included with a certain series resistance?
If so, have passive filters been altered? Lower resistance coils?
Q may have been lowered.
/ Anders
Old 12th September 2006, 07:53 PM   #26
JRKO's Avatar
bubbuuulelbobobllbbobooblllleeeee
Thats the sound of me being out of my depth.....and slipping under the water.
Think no electronics experiance and then subtract an iq of 200
Old 12th September 2006, 08:05 PM   #27
JRKO's Avatar
I have down loaded a basic version of WinISD and have entered the basic TS specs as posted previously. I cant work out the rest but I am sure as with all things electrical there are calculations to generate the missing info.
I have used what specs I have and I dont seem to be able to make a hige amont of difference whatever I do to the ports or the cabinet. Even a sealed cabinet has almost the same roll off.
What gives (is it just me?)
Old 12th September 2006, 08:25 PM   #28
No snake oil
AKN's Avatar
Hi!
Found this response graph:
http://www.hilberink.nl/codehans/tannoy59.htm
30Hz with little EQ should be possible.
Can you post some pics?
/ Anders
Old 13th September 2006, 09:29 AM   #29
R.I.P.
Originally posted by 4fun
Hi!
you are correct I didn't include the effects of series resistance
of the crossover coils, which raises the effective Qts of the driver.
See new Qts with series inductor here http://www.mhsoft.nl/spk_calc.asp
I have used what specs I have and I dont seem to be able to make a huge amont of difference whatever I do to the ports or the cabinet. Even a sealed cabinet has almost the same roll off.
Nope, you are not doing anything basically wrong. As stated you
need some form of bass boost. Experimenting with putting a BSC
type circuit between the CD player and its input is a possibility.
With 6dB to 10dB maximum boost depending on room gain
placement etc bass down to 30Hz is certainly possible, and
with two 15"s at reproduction levels you can easily hear.
/sreten.
Sub integrationHide this!Advertise here!
Tad 4001 , ET-703 integration limono Multi-Way 7 28th November 2010 09:17 PM
Clock integration, how to do it? lumanauw Digital Source 6 5th November 2009 02:10 PM
sub integration with sealed mains regal Subwoofers 6 6th August 2005 03:29 PM
sub integration with fostex regal Full Range 4 19th July 2005 04:08 PM
Driver materials integration audiobomber Multi-Way 2 22nd April 2005 04:22 PM
