Old 6th September 2006, 01:54 AM   #1
mpmarino's Avatar
Default coffee table open baffle??
My current project is not nearly completed but like most of us the brain is partially on the next one.
I will be needing a subwoofer. surprise
I am having thoughts of building a coffee table with an open baffle sub as per the pathetic attached pic. I am thinking of a few advantages:
1) I will get a new coffee table for my coffee
2) As per the usual coffee table sub setup, it won't intrude in on the room.
3) The isolating baffles will be quite large, allowing for good bass.
4) ?
4) I will get a new coffee table for my coffee
shoot it down please.
Crazy Yankee.
Old 6th September 2006, 02:10 AM   #2
mrshow4u's Avatar
It sounds interesting. You might have to eq to compensate for the front to back cancellation. There will be a bass null along the baffle plane. I want to try an H-Baffle soon myself
".........These go to eleven"
Old 6th September 2006, 02:25 AM   #3
Send a message via AIM to ocool_15 Send a message via Yahoo to ocool_15
If you could place say a single woofer on an end and use a larger U baffle would that not allow you to use less equalization due to a larger baffle length?
Old 6th September 2006, 02:38 AM   #4
mpmarino's Avatar
or how 'bout 4 12" woofers. This time in the pic we're looking down through the table top
dunno, ocool
Crazy Yankee.
Old 6th September 2006, 02:40 AM   #5
mrshow4u's Avatar
Yup, I think so. I think the baffle size gets really large to prevent cancellation of the lower freqs. It might be diminishing returns?? Large power,to compensate for the roll-off due to a smallish baffle, is pretty cheap. It seems like some sort of eq below Fs is always handy. I'm going to be trying one of these H-Baffle things, I'm really curious now.
Old 6th September 2006, 07:56 PM   #6
Kensai is offline Kensai  United States
Send a message via AIM to Kensai
You might just use 2 15" or larger, each in a ripole config, and use the resulting ripole boxes as the legs of the table. This way you should (theoretically) get lower response due to the ripole config lowering the drivers' Fs, and the drivers will be completely protected from feet or anything that might go under the table. You will definitely need alot of amp power to get these up to level with your mains/satellites, but another advantage would be that you could run them stereo (I seem to be able to locate the source of bass further down in frequency than is normal, so I like that), or at the very least run the things with a pair of cheaper amp channels instead of needing a more expensive, single monster channel.
Kensai
Old 6th September 2006, 08:29 PM   #7
Default Pathetic Drawing???
I think the drawing is definately NOT pathetic.
Much easier to read and understand than the convoluted stuff that usually happens between my ears.
Sorry I can't be any help on how the design should work, which explains why I'm the one asking instead of answering the questions around here.
Probably a silly question, but ........
Old 6th September 2006, 08:57 PM   #8
renfrow is offline renfrow  United States
renfrow's Avatar
dunno, ocool
I like the looks of this, would everything be wired in phase?
You'd probably want to cover the top with cork sheets or something that would minimize cups sliding off due to vibrations :-)
Tom.
Now, we can do this the hard way, or... well, actually there's just the hard way.
-- Buffy Summers (Buffy the Vampire Slayer)
Old 6th September 2006, 11:36 PM   #9
mpmarino's Avatar
Tom.
Yes, in this configuration I would say they should all be in phase. I have a feeling vibes would be minimal. With the woofs mounted opposite to each other, I think most of the vibe energy would cancel.
Crazy Yankee.
Old 7th September 2006, 03:46 AM   #10
adason is offline adason  United States
adason's Avatar
hi
or maybe you can forget open baffle bass and do some real bass with this coffee table
http://www.decware.com/WO32/wo32.htm
ed
ps: been there done that, open baffle bass is not easy, simply put, you need large baffle with woofers with large Xmax on it,
thats all
A coffee table idea. venki Subwoofers 5 22nd May 2009 08:09 PM
sub-woofer "coffee table" zafira1981 Subwoofers 5 5th January 2008 12:52 PM
Anyone have a Decware WO32 coffee table sub? rcavictim Subwoofers 4 4th July 2007 10:22 PM
Australians- what solid timbers for baffle? (open baffle loudspeaker) tktran Multi-Way 13 29th November 2004 11:09 PM
Help needed for high power coffee table subwoofer project Sixthofmay Subwoofers 26 6th July 2004 12:31 AM
Page generated in 0.11482 seconds (79.42% PHP - 20.58% MySQL) with 11 queries
