Old 3rd September 2006, 12:13 AM   #1
Default How does this diy subwoofer look?
What do you think about this Dayton Titanic project?
Here are the final specs:
Dayton Titanic MKIII 15"
250w Rhthmik Audio Plate Amp (adjustable rumble filter @ 17Hz)
200 liter ported enclosure tuned to 19Hz
And the graphs:
Green = Dayton Titanic 15", 250w, 200 liter, 19hz tuning
Orange = Dayton DVC 15" (Tempest), 250w, 350 liter, 17.8Hz tuning [my original project]
Red = Dayton DVC 15", 250w, 200 liter, 19hz tuning.
Dayton DVC Xmax - 15.1mm
Dayton Titanic Xmax - 20.5mm.
Is 19Hz a good tuning frequency for the Titanic project??
As you can see, I plugged in my orginal DVC project in WinISD except with a 200L enclosure, and 19Hz tuning frequency (same as the Titanic project), and plotted it alongside my Titanic project. It looks very similar to the Titanic Project. Is there any advantage to using the Titanic over the DVC in 200 liters / 250w? I know the Titanic is built better, but will I get better SQ with the Titanic over the DVC (in 250l w/ 250w)?
Any simple changes to this design that you think will make it better, I will be willing to do. How will this compare to my original 350L Dayton DVC design?
Any other graphs you need, I will be happy to post.
--Thanks
--Rocko
Old 3rd September 2006, 01:37 AM   #2
I built a sub using the dayton DVC sub here: charting progress on my DIY subwoofer.
my tuning is about 19hz. I used 2 15" PR's and about 3 cubic feet to do it. also a 9db boost centered about the 20 hz mark with some add-in resistance on the amp.
Looks great to me. although I get sick with deep bass it hasn't dissapointed once!
mike
Old 4th September 2006, 03:56 AM   #3
BassAwdyO's Avatar
Send a message via AIM to BassAwdyO
the orange line looks nice
The golden rule of DIY:
Build nice, or build twice!
Old 4th September 2006, 11:38 PM   #4
Notax is offline Notax  Montenegro
Notax's Avatar
For 15" Titanic.
Vb=100-120 L, bigger box - group delay is much bigger.
Fb= 24-26 Hz
Dt=110-120mm
Simulation is.....simulation.
Old 18th September 2006, 09:27 PM   #5
Send a message via MSN to xstephanx
bigger box = mroe group delay? i believe ive talked to you about this, and it isnt so. properly designed vented subs can have jsut as good GD as sealed. oh, and i would be surpriused if you coudl even ehar a high group delay at 20hz, if you can even hear a 20hz fundamental.
simulation is simulation, but math is math.
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!!
EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!!
Old 19th September 2006, 09:28 AM   #6
Notax's Avatar
Example?
Old 22nd September 2006, 10:18 PM   #7
example? try VERY low tuned boxes, below FS, and a large box, you can get GD VERY VERY low that way. and where there IS group delay, is below your range of eharing, so does it really matter?
Old 23rd September 2006, 01:37 AM   #8
dscline is offline dscline  United States
Default Re: How does this diy subwoofer look?
No offense, but after your thread at AVS, how many more opinions can you possibly get? You need to just bite the bullet and build it.
Old 23rd September 2006, 11:23 AM   #9
Notax's Avatar
You must be kidding.
Example? Some real bass unit with T/S parameters and your suggestion:
Vb=? box volume, netto
Fb=? tuning freq.
Dt=? tunnel diameter
Lt=? tunnel lenght
Old 23rd September 2006, 03:48 PM   #10
Ron E is offline Ron E  United States
Ron E's Avatar
The value of the group delay is meaningless without knowing the frequency at which it occurs and the cutoff frequency of the system.
People have latched on to "group delay" recently IMO because of the proliferation of programs which calculate it and mostly because they don't understand it - it is a magic phrase, somewhat like "phase" that is often mentioned in reviews and websites but not explained.
An EBS type design, where the box is 1.5-2 times the typical size and tuned low enough to provide a shelf in the response, will show a very low group delay. It has a step response which is basically equivalent to a sealed box, but with a LF ringing superimposed. If the tuning is low enough, there is no chance of your hearing the ringing - and it is "virtually" the same as a sealed box, in a sense.
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Science is a way of thinking much more than it is a body of knowledge. --Carl Sagan
subwoofer under bed Potato42 Subwoofers 7 13th January 2009 02:21 PM
subwoofer project, which subwoofer? Davlaf Subwoofers 12 9th November 2006 03:59 AM
Subwoofer crossover / subwoofer module design derMichi Subwoofers 4 20th April 2006 10:31 AM
how to connect a non powered subwoofer to a stereo system without a subwoofer output JSD777 Multi-Way 4 20th September 2005 03:19 PM
I need help with subwoofer deisign: HUGE inexpensive subwoofer hottyson Subwoofers 16 4th May 2004 03:51 AM
Page generated in 0.10939 seconds (79.75% PHP - 20.25% MySQL) with 11 queries
