#11 |
LOL
google is your friend. |
#12 |
downfiring will cause some sag in the suspension. I have seen the 5% figure quoted elsewhere. If you can see/measure any sag difference between upfireing and downfiring, you have probably already exceeded the 5% limit on a low Xmax driver. Stick with side firing except for a driver specially developed for vertical mounting.
regards Andrew T. |
#13 |
I've seen the 5% number too. But I don't know how it is derived.
It seems like it would be different for different drivers. I have never before heard of drivers specially designed for vertical firing. That sound intriging. I have also never seen anything in print which analyzes how long the legs need to be, and the effect of the design of being so close to the floor. |
#14 |
I think if the box is sealed, then sag would be minimal as the driver effectivley is held by the air pressure of the box - does that make sense?
Anyway I quite like the look of SVS subwoofers. http://www.svsound.com/ |
#15 | |
regards Andrew T. |
#16 |
Why is that rubbish?
The only way the driver can move is if the volume of air in the box increases, this can only happen if it is not properly sealed. Of course the other way the driver moves is by the force applied to it from a signal applied to the voice coil, in this instance the air inside the box is being compressed - that is why a sealed box is often referred to as working like a spring. |
#17 | |
Now, you can argue that eventually, the box's pressure will equalize (no box is totally impermeable). And that's a correct argument. But it really means that the cone sag increases with time until that equilibration occurs.
"...we stumble and get up, we are sad, confident, insecure, feel loneliness and joy and love. There is nothing more; but I want nothing more.” - Christopher Hitchens 1949-2011 |
#18 |
and what if the air temperature in the box changes?
regards Andrew T. |
#19 |
Hey good point - I haden thought of that!
(BTW I think Im completely wrong about sag). I guess the trend nowadays is to go for forward firing because more drivers have very large soft surrounds & high xmax - maybe something to do with the low Q, low efficiency, low Fs woofers and therefore low Vb. |
#20 |
you're allowed ONE. what is the sanction for a second?
regards Andrew T. |
| Why did my amp start on fire? | soundNERD | Chip Amps | 39 | 30th October 2004 04:33 PM |
| fire up Aleph 30 | wijgers | Pass Labs | 14 | 28th April 2004 04:42 PM |
| Amp on fire | Ford_V6 | Solid State | 12 | 2nd April 2003 01:27 PM |
| Amp on Fire! | peter5 | Solid State | 6 | 7th January 2002 12:35 PM |
| Page generated in 0.10047 seconds (81.06% PHP - 18.94% MySQL) with 10 queries |
