Old 27th August 2006, 09:38 PM   #1
yboorg is offline yboorg  New Zealand
Default TDA7294 failure
Can anyone shed any light on why my TDA7294 blew up. It is in a Polk Audio Sub and just decided one day to blow a fuse. After replacing the fuse and powering up it did it again. Turned out the chip was fried so a purchased a new one and fit it to the PCB.
(note: at the point of testing the 2nd chip, the heat sink was not fitted, nor was the speaker connected.)
I turned on the power and it the chip blew almost straight away.
The voltage to the chip is 27v on +PVs and +Vs (both pins connected on PCB). -27v on -PVs and -Vs (both pins connected on PCB).
On Standby the standby and mute pins both see 13.5v changing to -6.4v when standby is switched to ON.
Was I wrong to turn on the power without the heat sink even though there was no load connected?
Both failed chips had holes in them in the same place.
Old 28th August 2006, 02:05 AM   #2
F1 FAN is offline F1 FAN  Canada
I doubt it should have blown so quickly even without a load but it would be wise to attach it to the heat sink before trying.
My guess would be that there is a dead short somewhere in the output on the PCB or the wires to the driver.
I would normally suspect that the voicecoil in the driver is fried but you indicate it was not connected.
Old 28th August 2006, 04:56 AM   #3
ashok's Avatar
Search for the TDA7924 threads. There is a warning about instant blow up if the two supply pins ( input stage and output stage ) do not stay within a few volts of each other. So if you have a resistor between output stage supply pins and input stage supply pins and these are blown , then 'bang' goes your chip.
READ the threads and check the application data for 7294 and 7293 . You might spot the problem with your unit.
Cheers.
AM
Old 28th August 2006, 09:23 AM   #4
Thanks mate, I'll check over the ouput carefully.
Old 28th August 2006, 09:23 AM   #5
I did spend quite a bit of time before I posted this equiry looking at the threads and you are right, there is a lot of info on this chip. However I found nothing that explains what is heppening with mine.
I am a little concerned with the "Boucherot cell" off the optput that on my PCB is a 4.7ohm resistor with a cap after it to ground. I am tempted to remove it as it could be the cause of the blow on startup.
Old 28th August 2006, 10:26 AM   #6
Did it Himself
richie00boy's Avatar
It's not wise to connect without heatsink at all. Before you remove the zobel/bucherot check it's resistance (and capacitance if your meter can do that) as it should be there.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 28th August 2006, 06:37 PM   #7
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
I have been building TDA7294 boards from time to time for several years now. Here goes some advice:
- Check for solderballs, solder bridges or bad soldering.
- Never solder a replacement chip without some heatsink attached, the heat applied to the pins will destroy it most times. Otherwise, you will have to solder the pins one by one leaving gentle time inbetween to prevent excess heat to build up.
- Even whith the heatsink attached, allow a few seconds for the chip to cool down after soldering each group of three or four pins or so.
- Replace the small electrolytic capacitors related to the chip, particularly the bootstrap one. They cost very little, yet they can cause new chips to blow instantaneously if they are faulty.
- The chip may blow if MUTE or STANDBY inputs are left "floating".
- Never remove the RC output cell, doing so may cause instability and ultimately destroy the IC.
- Be aware that a new chip may be partially damaged due to excess soldering heat or electrostatic discharge and it will fail after a few hours or days of operation. TDA7294 seemed to be quite a delicate IC ultil it's mounted in a PCB.
I use to feel like the small child in The Emperor's New Clothes tale
Old 28th August 2006, 07:10 PM   #8
Cro maniac's Avatar
Send a message via Skype™ to Cro maniac
I have built about dozen of TDA7293 amps, and have found the bootstrap capacitor is the greatest problem maker. They degrade after time and at first cause some degradation of sound, and later blowing of the chips.
Old 28th August 2006, 08:46 PM   #9
Thanks for all the great advise.
One more question, with no input, I assumed that I would have no output. Is this assumption correct or do I get output on power up?
Old 29th August 2006, 02:38 AM   #10
ashok's Avatar
".....................with no input, I assumed that I would have no output................"
No output ! Did you really doubt that ?
AM
Tda7294 e_fortier Chip Amps 2 27th November 2008 01:33 PM
TDA7294. . . help! ;) danielwritesbac Chip Amps 3 19th April 2008 06:58 AM
My TDA7294 Amp panson_hk Chip Amps 1 27th June 2007 01:06 PM
Need help on tda7294 amp Fossil Chip Amps 6 20th April 2005 02:53 PM
Tda7294 Angel Puerto Chip Amps 6 21st August 2003 02:08 PM
Page generated in 0.09213 seconds (86.65% PHP - 13.35% MySQL) with 10 queries
