operation below fs
operation below fs
Old 28th August 2006, 07:59 AM   #11
paulspencer is offline paulspencer  Australia
paulspencer's Avatar
Those are some great links.
After reading that Nousaine article, I do wonder why he doesn't consider horn loaded. My simulations indicated you could exceed 120 dB easily @ 20 Hz with two high excursion 12" drivers with much less power than all but the cheapest of plate amps. Required footprint is only about 2 x 0.5m with a large floor to ceiling box. Not that bad really. If I had room I would have done it by now.
When I was working on the design, another who had built a smaller bass horn suggested that it could go well below 20 Hz due to the corner expansion. Given a spare basement, you could also build some very large vented boxes or bandpass boxes to get high SPL @ 10 Hz if unhappy with the extension of the horn.
The horn could actually match the SPL of the IB on the low end, given the same number of drivers. Not that you would pull this off since the horn would be huge then with that many drivers.
Old 31st August 2006, 10:08 PM   #12
kingdaddy is offline kingdaddy  United States
kingdaddy's Avatar
I've played 7Hz test tones on my 4-18" Avalanche IB with no problem and still quite strong on the SPL, but the electronics brick wall there and as far as I know you wont find many combinations of electronics that wont stop you somewhere before 5Hz. Also if your looking for any measurements or want to do some real experimenting here I donít know how you would as I donít know of any test equipment readably available that will test anything accurately down this low. BTW, why?
http://kingdaddy.linaeum.com/
Old 2nd September 2006, 04:18 PM   #13
Bogie is offline Bogie  United States
It's fun to hack off the guys at the seismic lab?
Old 3rd September 2006, 11:04 AM   #14
I have just downloaded Stig Tangen's article from post4.
Can I assume the content as gospel? or are there any corrections that I should account for?
22Hz performance from a driver with Fs=40Hz seems more than impressive!
regards Andrew T.
Old 3rd September 2006, 02:32 PM   #15
zenmasterbrian is offline zenmasterbrian  United States
The why is to experiement with infrasonics in music. This thread is a continuation of the Giant Subwoofer thread where this was first broached.
There are 3 pipe organs in the world that have the 64' octave, which has its lowest note, C at 8hz. Is that music, or is it a sound effect?
I am not sure, but I'd like to experiment . I think it is a fascinating subject. If its possible to go lower, OK.
Do you have a link for that 18" Avalanche? I tried to find that once and could not.
Old 3rd September 2006, 06:08 PM   #16
qi is offline qi
Have you heard of GOOGLE?
I found it in like 30 seconds...
http://www.frappr.com/?a=photo&gid=3...sh_slideticker
Old 3rd September 2006, 06:42 PM   #17
AKN is offline AKN  Sweden
No snake oil
AKN's Avatar
operation below fs Send a message via MSN to AKN
He has active correction.
"The first two sections are the equalizer. The two last 2nd order filters are in combination a 4th order Linkwitz-Riley filter"
The woofer he is using has Qtc around 0.3 so it is possible to have sufficient gain from BR. Tuning is also low. Resulting in a shelf response that he is EQing flat.
The site seems to have lost all pictures that backed up his article.
Edit:
Here's one sim i made with JBL 2226 in 220L box tuned to 22Hz. Not impossible to EQ flat.
/ Anders
Old 3rd September 2006, 07:36 PM   #18
Hi 4fun,
thanks for the clarification.
What about mistakes or rose tinted glasses in the Stig article?
regards Andrew T.
Old 5th September 2006, 04:38 AM   #19
qi, IB Cult? I don't know what to make of that. All those boxes with the back side of the woofer exposed? Are those Avalanche? I really never heard of that name and have not been able to find them.
Old 5th September 2006, 04:47 AM   #20
Enough woofs, with enough surface area, and enough xmax, and with a little judicious equalization, you're there. Granted, with a single one, you're not going to be able to rumble loud, but you _can_ rumble... And when you get into the folks who build walls out of them, well...
The limiting factors are construction of the chamber (the listening room) and how much $$$ you can throw at it.
operation below fsHide this!Advertise here!
CFB and A2 operation hemgjord Tubes / Valves 2 9th September 2008 10:42 PM
dcc salvage operation jaudio Digital Source 1 27th October 2006 12:24 PM
Balanced Operation gchrist Pass Labs 1 21st July 2003 01:23 PM
Class B operation ding Solid State 17 8th October 2001 05:37 AM
Copyright ©1999-2017 diyAudio
