Old 21st August 2006, 09:46 AM   #1
Default Subwoofer Servo
I'm looking for info on how to construct a Subwoofer Servo for a DIY project.
If anyone knows of any books, web pages, etc, or knows how to do it them selves please send me the info.
Old 21st August 2006, 12:47 PM   #2
mike.e is offline mike.e  New Zealand
mike.e's Avatar
Send a message via ICQ to mike.e Send a message via MSN to mike.e
Theres a thread or three on the subwoofer servo stuff in this forum.(search for motional feedback also)
2ways
- Using 2nd Voice coil as pickup (see electronics world 1990s)
- Using a transducer that measures the subwoofer movement.
http://www.diyaudio.com/forums/searc...der=descending
The EW article I used to have scans of,stated that output from two 10" DCV average sorts of car woofers,with servo on,had <5% THD at 15hz. SPL wasnt stated,but it was probably audible (if they are decent guys lol) - 105dB +.
Old 3rd September 2006, 03:44 PM   #3
sletol is offline sletol  Norway
I don’t know if it has been discussed here before, but there is a possible principal weakness with servo-controlled bass speakers, using sensors on the driver cone. May be worth considering:
When the speaker and a node (of one of the standing waves in the room) are spatially coinciding, the speaker cone movement will be reduced because of the higher acoustic impedance. (In other words, here the pressure is high and the movement of air small). At such frequencies, the cone’s coupling to the air is at its most effective, and if the servo tries to compensate for the reduced cone movement by increased input from the amp, the standing waves will only reach new heights, degrading the final result as never before…
(just something I read somewhere).
But after all, the standing waves in the typical listening room, isn't this the only remaining big problem? I mean, anybody can build or buy a subwoofer which gives the wanted level and frequency range etc.
Old 3rd September 2006, 05:31 PM   #4
troystg is offline troystg  United States
troystg's Avatar
Mr. Erath has a servo of sorts but it forms a loop from pre-amp signal to amp output. The actual driver is in a sealed enclosure that resonates at 70Hz and have a "known" response.
He has a couple of patents on it but if your DIY'ing it you can build it yourself.
I bought a couple of the car units(one for me and one for my brother) and a home unit. I used a Bryston 4b and a pair of 15" woofers in a 1.25 cu ft. ea. enclosures. Flat, tight and responsive down to 20Hz.
Crossed over @125Hz to a JRDG Model 2 driving a pair of B&W Matrix 805's. Sounded great but the front port on the B&W's was not ideal. @ 125Hz it was more of a bi-amped 3 way instead of a sat /sub system.
He has just "micro-ised" the unit and made it very small. He is building my new one now. This one will be active speakers with 2 x 10" Aluminum woofers, B&W 6.5 " mid(robbed from the 805's) and SS Revelator tweeters bi-amped with UcD 180AD on top and ST on bottom.
Sorry to digress.
Anyway I mentioned this since it is a "third type" of servo. But this one's loop only encompasses the processing and amp.
Troy
Thinking positive doesn't make things better, it makes you a better person.
Old 5th September 2006, 12:13 PM   #5
Check this reply from me, I used a microphone and you can see a 3 db improvement in room response at 70 hertz.
Because a microphone senses air pressure instead of acceleration, the room modes get somewhat equalized.
The effect is not very high because the room modes are not very high at the cone.
Old 6th September 2006, 01:29 AM   #6
Still a nice result, bobo.
I wonder how the curves would look if the mic was mounted an inch or two before the cone. The same, more or less?
Old 6th September 2006, 08:34 AM   #7
Smile Thanks
Thank You all that replied to my post.
Old 6th September 2006, 09:20 AM   #8
Smile Sub Servo
The goal of this project is to see what I can build and have it work. Too me the more complex the bigger challenge and the bigger reward.
I'm just trying to push what I'm able to do and have it produce sound.
The quality of the sound is secondary. In my next DYI projects I will worry about that.
At the moment I'm trying to learn as much as I can and the only way to learn is to build some thing.
Thanks to All.
Old 6th September 2006, 11:15 PM   #9
Retsel is offline Retsel  United States
Rythmic offers a servo subwoofer kit that you could build to learn from.
You could purchase a used Genesis or Velodyne sub which are also servo controlled (the Genesis is probably better).
Retsel
Old 9th September 2006, 03:25 AM   #10
dangus is offline dangus  Canada
Just a thought: how about a pressure transducer measuring the pressure inside the cabinet? There are little semiconductor strain gauge pressure sensors that are fast enough to be used as microphones, and presumably the pressure inside the box can be related to sound output. And that may even be more accurate than just measuring cone movement.
Spica Servo Subwoofer willworkforfood Subwoofers 0 29th January 2008 04:21 AM
Ultra sound transducer for servo feedback subwoofer? e96mlo Subwoofers 27 14th February 2006 12:21 PM
Servo subwoofer using 15" driver kanaddict Subwoofers 2 20th December 2005 10:54 AM
Servo-feedback Subwoofer dswiston Digital Source 25 26th October 2005 05:07 AM
Servo rotary subwoofer! Audiophilenoob Subwoofers 17 6th October 2005 12:37 AM
Page generated in 0.12650 seconds (82.07% PHP - 17.93% MySQL) with 10 queries
