OB Sub, which amp?
thinking of making an OB speaker (on my fullrage thread) and was wondering if there was a sub amp that would drive say 2 Dayton RS225's each side, or would i have to use one sub amp per channel, if i can, i would like to use the high pass filter on the sub for the FullRanger on top.
I'd go with 8 ohm versions, wire them parallel to get a 4 ohm load for each amp channel. Behringer A500 is a good choice. 230w into 4 ohms per channel. I doubt you would need more than this for OB use. If this were a box sub, then I'd suggest Behringer EP2500 with 650w into 4 ohms per channel or 1200 into 2 ohms. The latter amp has a fan and so would have to go in another room, or in floor/ceiling.
