#21 | |
What shape box of ~ 10L takes a 15" pipe ? Cheapy Passive Sub? Quote:
#22 |
Sreten,
I obviously don't know my may around Winisd yet. Your comments shed a lot of light on the issue for me. A passive radiator it is. The only problem with that is I can't find a commercially available unit that yields a flat response below 50Hz. The 10" from PartsExpress gets close, still a bit of a bump and an F3 at around 45Hz. The 8" looks great but stops at 50 Hz and has a lower Xmax than the driver. No great solution with either. What I probably need to do is use the flat PR and then add some boost. Stupid me. I already ordered the amp and it doesn't have any boost available. I jumped too quick on this project w/o doing all the modeling I should have up front. javascript:smilie(' dead Thanks, Steve |
#23 |
Greets!
Sorry about that, it seemed reasonable to assume that someone who's been around awhile would have seen/read the many dozens of threads across the forums about TLs, MLTLs, Voigt pipes, how to use MJK's MathCad simming worksheets, etc., not to mention the humongous Bigger is Better (BIB) thread and its various spin-offs. Anyway, I answered your primary Q and you can do forum searches to get 'up to speed' with all the rest if you're interested enough. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#24 |
A reasonable assumption about me being around for a while.
But although I registered for this site a few years back I haven't checked into the loudspeaker threads at all. And my past speaker building never took me into much in the way of low frequency design. I've always just done done flat sealed boxes. I am really quite the newbie with respect to LF design. I'll do a little more poking around on my own before asking any more questions that I now realize are pretty elementary to the rest of this forum. Thanks for your feedback. |
| Suggestions for a small room? | StoneT | Full Range | 4 | 25th October 2007 02:08 AM |
| FS: 4 8" TB Neo Subwoofers W8-1363SA Brand New | saabracer23 | Swap Meet | 9 | 13th October 2007 06:34 PM |
| Small 2 way standmount suggestions | Puggie | Multi-Way | 0 | 26th January 2007 04:09 PM |
| small bookshelf project suggestions please | gychang | Full Range | 4 | 10th November 2006 05:32 PM |
| Suggestions for small 2-way system? | BorisH | Multi-Way | 3 | 28th March 2005 06:32 PM |
| Page generated in 0.08498 seconds (74.59% PHP - 25.41% MySQL) with 11 queries |
