Old 3rd August 2006, 08:39 PM   #1
Default building a sonotube from the parts from a 12 inch partsexpress sub
I have a 12 inch downward firing partsexpress subwoofer
and i would rather have a sonotube design.
what is the best way to figure out the design for building
the sonotube sub? i want a sonotube because
its smaller footprint should fit behind my couch.
anyadvice would be greatly appreciated. i am looking to
use the driver and amplifier from the partsexpress
sub.
thanks again and i have learned a great deal from just lurking
here.
Old 3rd August 2006, 09:21 PM   #2
preiter is offline preiter  United States
preiter's Avatar
As far as I know, a Sonotube subwoofer is just a subwoofer that uses a Sonotube in its construction. It can still be sealed, ported or a transmission line. That's the first decision you need to make.
Old 3rd August 2006, 09:42 PM   #3
auplater's Avatar
Default sonosub
here's a 12" partsexpress Titanic MkII sonosub from ~2001
The hardest part of building is the endcaps, I turned mine on a Shopsmith lathe, but with a large sander you can clean up a jigsaw cut, or you can make a circle template for a router and cut them...
"...His brain is squirming like a toad..." Jim Morrison
Old 3rd August 2006, 10:38 PM   #4
Default thanks for the advice
i'm pretty good with woodworking and my questions are
more towards how do i determine the dimensions of the sonotube?
there must be a formula where you enter the driver charectoristics
and you end up with the tube diameter, length, port diameter
and lenghth.
that is what i am looking for.
thanks again.
my searching skills are not turning up with much.
any recipes on line?
Old 3rd August 2006, 11:16 PM   #5
Mikey p is offline Mikey p  Canada
You enter the subs characteristics into a sub modelling program to determine the volume needed. (WinISD comes to mind). Then you use the sonotube calculator to determine the diameter and length of tube that you need.
http://www.quux.net/roo/diy/sonosub/sonocalc.html
Old 3rd August 2006, 11:22 PM   #6
badman is offline badman  United States
Custom Title
badman's Avatar
win isd
bass box
any number of online calculators
www.google.com
There's a TON of information out there. The volume of a sonotube is 3.14159 X (inner diameter/2)^2 X height.
I write for www.enjoythemusic.com in the DIY section. You may find yourself getting a preview of a project in-progress. Be warned!
Old 4th August 2006, 12:39 AM   #7
Default thanks
thanks- that was exactly what i was looking for.
thanks again.
Old 4th August 2006, 01:48 AM   #8
Send a message via AIM to TheWacoKid
You design the enclosure just like you would any other ported/sealed/TL/bandpass. Then you just build the sonotube enclosure with the correct volume/tuning/port area/etc.
Old 4th August 2006, 01:56 AM   #9
auplater's Avatar
Default Re: thanks for the advice
and lenghth.
thanks again.
Heres an excel spreadsheet for this sub... you can replace the params with those for your 12 incher (for the sealed version) and the ported version
Old 4th August 2006, 04:14 AM   #10
I recently built a sonotube 12 inch sub that would be described as TL, it was pretty simple, 1/4 wavelength of 33 hz (driver resonence) is aprox 8 feet. I simply siliconed the driver to the tube and filled with dampening material. As I cross over low aprox 60 hz there is no need to place the driver 1/5 length of pipe. It sounds fantastic.
I then installed an 18 inch 98db driver in a 10 ft sonotube, fiberglass fill in a 250 seat cinema. The staff and customers seem to love it.
I have been told that a reponse from 22 hz can be expected but do not understand why.
Parts express coaxial 12 inch? Fast1one Multi-Way 3 10th April 2009 04:31 PM
Need help building Sonotube Subwoofer ketchamftw Subwoofers 16 13th March 2009 05:52 AM
Building a headphone amp from parts Smokehouse Bob Headphone Systems 13 13th August 2007 03:26 PM
Page generated in 0.12000 seconds (75.55% PHP - 24.45% MySQL) with 11 queries
