Old 2nd August 2006, 02:35 PM   #1
Default Peerless XLS10 with XLS 10 slave 265gr.
Hi all,
I'm new here, so I hope somebody can help me out.
I'm wan't to build a subwoofer to complete the bottom of my Dynaudio BM 6 studio monitors. http://www.dynaudioacoustics.com/Default.asp?Id=275
I ordered a Peerless 10" with a passive slave 265grams to go in a front loaded cabinet. I don't wan't a booming sub, just a good frequence response to control the lowest part of the material I mix.
Got some discription from the internet and made a drawing. Can give me some clues if I'm going to get good results?
I'm gonna put some more information on this site as soon as I start building...
Thanx, John
Old 2nd August 2006, 06:48 PM   #2
VT67 is offline VT67  Belgium
VT67's Avatar
Have you seen this design already? Maybe it can give you an idea about the possible end result.
http://www.hardwareanalysis.com/content/article/1789/
Old 6th August 2006, 07:39 AM   #3
Thnx GeWa,
I saw the article, and I've started building after consulting some guys from Speaker & Co. I also bought the Peerless @ Speaker & Co, it only took 3 days... so I could'nt wait getting started. So here is the first picture...
Old 6th August 2006, 10:45 AM   #4
they fit almost air tight
Old 6th August 2006, 02:31 PM   #5
c3ham is offline c3ham  United Kingdom
what did u use to cut the holes out?
Old 6th August 2006, 03:32 PM   #6
VT67's Avatar
Looks like it's coming along nicely. With which program did you made the drawing that you show in post #1. I've been tempted to build me one of these for a while now so I'm really curious to the end result and your comments about this sub.
Old 6th August 2006, 04:42 PM   #7
it looks like he has used google sketchup for his drawing
Old 6th August 2006, 07:40 PM   #8
I used a Plunge Router to cut the holes, and sketch-up for the drawing.
Old 7th August 2006, 06:24 AM   #9
with a jig?
Old 7th August 2006, 02:14 PM   #10
I used the standard guide that comes with the router, turned it up side down, and put it back in the router like u use it when you want to cut straight guided lines or edges. Mine has 2 holes in it, in line with the bit. I drilled a 4mm hole in the center of the speaker position and used a 5mm screw from the bottom center of the hole. As it comes out at the other end, you can place the little hole around it, and then adjust it exactly to get the desired diameter. It’s very accurate, the speaker just fit in, not able to move at all.
I have finished the cabinet, and doing some test right now, my first impression is amazing! It perfectly matches with the Dynaudio BM 6 speakers. For now I’m using an Alesis RA 500 amplifier directly connected to the sub out of my soundcard. Still don’t now what kind of amp I’m going to use; Thommessen Proteus SW2.5, Hypex DS 2.0. Suggestions are welcome.
peerless xls10 with 2 xls10P radiators Asdonk Subwoofers 0 16th January 2008 11:10 AM
Brand new Peerless XLS10 subs £50 each ShinOBIWAN Swap Meet 8 29th July 2007 08:49 PM
Peerless XLS10 and passive radiator design greg_mcquaid Subwoofers 7 15th March 2007 10:59 PM
Peerless XLS10 CAR (830514) as home sub? Dirk Subwoofers 11 5th January 2005 05:09 PM
Enclosure for a Peerless XLS10 needed. Kram Multi-Way 57 6th April 2004 04:03 PM
Page generated in 0.09736 seconds (79.87% PHP - 20.13% MySQL) with 11 queries
