Old 29th July 2006, 10:35 PM   #1
JaRoD is offline JaRoD  Finland
Default subwoofer moving on the floor...
I have a peerless xls 10" and a 12" passive radiator in a 36 liter box and it starts moving around on the floor when there's bass under about 25 hz. The passive radiator is tuned to about 22 hz, not exactly sure. I have it in a corner and there's a large peak (~5 db) at 25 and the responce falls faster under that.
I have put on some rubber feet but that only helps a bit. Sitting on the box also helps but that's not practical in the long or short run But even sitting on it doesn't help at some frequencies and at loud enough spl... Having a downfiring passive radiator might help but then again since the weight of the membrane is about 600g it will dip down something like 3-4 mm and I'm not sure if it will dip down even more in the long run. It does have an xmec of 24 mm so loosing 3 mm isn't too bad.
The moving on the floor isn't the most annoying part even if it's annoying, it's the noise that comes from it moving that's bad Using 2 pr's on opposing sides might work since the mechanical movement will take out eachother but that would require alot more weight on the rp's. Probably something like 2 times more since I can't make the box any bigger or I'll get a huge peak at resonance.
So, anyone have any ideas? Or any experience with a similar setup?
Old 29th July 2006, 11:18 PM   #2
AKN is offline AKN  Sweden
Enjoy good sound
AKN's Avatar
Hi Jarod!
If it is just right otherwise, you can just make the whole box heavier so you increase ratio between moving mass and box.
/ Anders
Old 30th July 2006, 03:10 PM   #3
To add 20 kg of weight to the box I'd have to build a box with about 6 cm thick walls... Then again, it might get more stable if it has more contact with the floor. And it would be nice to be able to move the box too.
But 20 kg might not be enough considering that it was still moving when I was sitting on the box...
Old 30th July 2006, 03:32 PM   #4
FastEddy's Avatar
Default Movable machinery
I would guess that the distance between the subwoofer drivers and your floor is quite small.
Consider: the way heavy machinery on a machine shop floor is sometimes moved, is by squirting air pressure under the base plate, thus suspending the machine on a thin cushion of higher pressure air. It might be that the distance between your drivers (and radiators) is such that increased air pressure at certain low freq. is enough to "suspend" or lift the whole box. Adding weigth (mass) to this box would probably have a very small effect.
I would suggest giving your box taller feet, increasing the gap btween base and floor. Laying down some heavy carpet would probably do it as well, but would also interfer with bass response.
This is all quite interesting. What is the gap distance between edges of your box and the (bare) floor? What at the outside box deminsions? ... Gap times area times pressure (differential) would equal upward thrust ... sound pressure being quite mechanical in nature.
Old 30th July 2006, 03:33 PM   #5
Did it Himself
richie00boy's Avatar
How thick material have you built it from? Does the sub house the amp as well? Is the drive unit facing the floor?
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 30th July 2006, 03:35 PM   #6
FastEddy's Avatar
Default !
richie00boy: " ... How much space around the drive unit to 'breathe'? ..."
So, richie00boy guessed the answer as well ...
Old 30th July 2006, 04:31 PM   #7
Enjoy good sound
AKN's Avatar
JaRoD,
Is the floor steady when sub start to moving around?
Adding solid weight to box is not the same as sitting on the box.
Some pictures or printings would be nice..........
/ Anders
Old 30th July 2006, 06:40 PM   #8
Mom, Mom come quick. It's alive!
regards Andrew T.
Old 30th July 2006, 07:03 PM   #9
Enjoy good sound
AKN's Avatar
/ Anders
Old 30th July 2006, 07:07 PM   #10
Here sis, come and sit on this!
The rest will get censored.
regards Andrew T.
New floor standers Tesla769 Multi-Way 7 13th January 2007 08:48 PM
Subwoofer enclosure under floor hypesconst Subwoofers 11 15th November 2005 05:35 PM
HOw close does driver need to be to floor to avoid floor bounce? Kanga Multi-Way 8 24th April 2003 06:09 AM
Replacing the floor Tim F Multi-Way 5 11th March 2003 09:14 PM
Page generated in 0.11583 seconds (80.31% PHP - 19.69% MySQL) with 10 queries
