Effects of non standard boundary loading a port exit?
Old 29th July 2006, 05:44 PM   #1
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Default Effects of non standard boundary loading a port exit?
Hi all,
I'm about to start work on a subwoofer design that was proposed by ScottG and I worked through the finaries and adapted it to my own needs.
Virtually everything has been discussed and agreed upon apart from the issue of the port and how it relates to the base. What am I talking about? Good question, a picture speaks a thousand words, so:
The upper part of the diagram is a cut away side view of the cabinet and the bit I'm interested in is the base which is black. The blue bit is the port and this fires into a cavity in the base (light grey) and this cavity exits from the front of the cabinet.
The lower portion of the diagram is again the base but looking down overhead, the blue circle is the port exit and the light grey the cavity.
What would be the effects of loading the port this way? Is there any benefit to tapering the cavity as shown in the diagram?
Old 29th July 2006, 06:39 PM   #2
johninCR is offline johninCR  United States
Send a message via AIM to johninCR Send a message via MSN to johninCR Send a message via Yahoo to johninCR
I'm not sure the effects will be very predictable. You've essentially got a port terminating in a cavity. I would stick with something more predictable and just go with a slot port from beginning to end.
Everyone has a photographic memory. It's just that most are out of film.
Old 29th July 2006, 09:12 PM   #3
Svante is offline Svante  Sweden
Svante's Avatar
The tube will appear slightly longer. The narrower passage, the longer it seems. I could imagine that one builds this box and measures fb and tunes it by changing the length of the internal tube.
I think the design has potential to behave better than just a straight tube, and that it would help to round the corners at the transision between the tube and the outlet.
Simulate loudspeakers: Basta!
Simulate the baffle step: The Edge
Old 30th July 2006, 04:29 PM   #4
ThomasW is offline ThomasW
In an ideal situation you want the port terminus no less than it's diameter away from any boundary. Doing this significantly decreases the potential for chuffing.
Hopefully you're going to use a flared port given the low tuning you propose. So it might be best to have no cavity, and elevate the bottom of the cab with legs. That ensures there's minimal resistance near the termius.
Old 30th July 2006, 06:31 PM   #5
Ron E is online now Ron E  United States
Ron E's Avatar
Koonce calls this style of port a diffuser port.
If you put a flare on the port and an inverse flare beneath it, you have what Polk Audio calls a Power Port.
There's Potential advantages, but you may want to test it, or consider what happens to air that exits in different directions from the port...nature likes symmetry...
Our species needs, and deserves, a citizenry with minds wide awake and a basic understanding of how the world works. --Carl Sagan
Armaments, universal debt, and planned obsolescence--those are the three pillars of Western prosperity. Aldous Huxley
Effects of non standard boundary loading a port exit?Hide this!Advertise here!
horn-loading standard dome tweeters thadman Multi-Way 12 19th December 2006 07:51 AM
4th order Bandpass- Effects of extending port outside of enclosure? treedog Subwoofers 7 17th January 2005 06:27 PM
Slot loading versus tuned port coolkhoa Multi-Way 5 20th January 2004 09:18 PM
Port Sizes and Effects??? Xyberz Multi-Way 26 30th August 2002 05:12 PM
Copyright ©1999-2017 diyAudio
