#21 |
I don't think a hydrophone is needed, or desired. If the effect you describe is audible in the air (and I'm guessing it is), then it should be possible to record it using conventional microphones.
Food for thought: A hydrophone's output would sound very different, but making a 'bass capable' one probably wouldn't be all that difficult - use a peizo transducer fitted to the inside of a disc of perspex or similar, having a matching disc to form the back, and a ring or two of perspex to act as spacers in between, with 'O' rings to seal the sections, bolting the whole together around the edge outside the 'O' ring margin. Feed the output of the transducer into a very high impedance (JFET) 1 - 10 megohms, and you'll get the lows. (The FET should be housed within your hydrophone.) Experiment with more compliant or thinner case materials, but be aware of water pressure effects on the casing. Remember, sound waves in water are very different than in air - water is virtually incompressible - and therefore even an apparently rigid diaphram material (by air standards) will work well in water. |
#22 | |
I'm hoping that getting a mic underwater and under 36" of ice will cure most of that. |
| desktop TL with 3" driver (with real bass) | Henkjan | Full Range | 26 | 29th January 2011 08:41 PM |
| "Certified Audiophile Recordings"? | sdclc126 | Music | 21 | 30th January 2008 01:56 PM |
| "life after the oil crash" yeah right | MetalDemonics30 | The Lounge | 15 | 7th May 2004 04:32 PM |
| Combing effects: How real in "real" rooms? | smeade1079 | Multi-Way | 3 | 10th March 2003 12:32 AM |
| Page generated in 0.07172 seconds (66.46% PHP - 33.54% MySQL) with 10 queries |
