Amplifier discussion needed!
Old 26th July 2006, 01:06 PM   #1
tf1216 is offline tf1216  United States
Default Amplifier discussion needed!
Following ShinOBIWAN's Perceive's 2.0 thread I am curious as to what amplifier is capable of powering a (2) B&C 12TBX100 drivers in parallel in a non-aligned bass reflex enclosure.
http://www.bcspeakers.com/index.php?...rizione_prod=2
Could a modded HPSA 1000 from Parts Express do the job?
Old 26th July 2006, 01:20 PM   #2
jan.didden is offline jan.didden  Europe
jan.didden's Avatar
Default Re: Amplifier discussion needed!
1 - check the impedance curve for lowest impedance and take a50% safety margin (downwards!);
2 - check speaker efficiency and the loudness you want to determine max power from the amp and take 3dB safety margin (upwards!);
3 - select amp that can deliver the required power at the min impedance.
4 - Done!
Now, you will get a lot of answers of people giving of-the-cuff answers. You can select one from those at random and take your chances...
Jan Didden
Music is dither to the brain; lets me think below the usual chaos - me
Get more Linear Audio for less! Check out my Autoranger and SilentSwitcher
Old 26th July 2006, 01:21 PM   #3
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
The power requirement would depend a lot on the size of box used, and to a smaller extent the tuning.
There is no such thing as a non-aligned bass reflex, they are all alignments, just some have been characterised and given names.
What mods were you proposing for the HPSA1000? It appears to be rated at 500 watts for 4 ohm loads which would probably be fine if they are real watts. I personally think there isn't enough heatsinking for that to be a real power figure.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Amplifier discussion needed!Hide this!Advertise here!
General power amplifier stability discussion (using Spice) cbdb Solid State 39 12th August 2012 09:42 AM
Discrete Class A amplifier for discussion. keantoken Solid State 11 17th January 2009 04:22 AM
There's a new Karlson-coupler discussion forum - rekruits needed freddi Multi-Way 0 29th December 2007 04:00 PM
Car amplifier help needed eRiCdWoNg Everything Else 3 1st April 2004 06:19 AM
Is a subwoofer needed for musical enjoyment?? dont argue folks(discussion) Andre Baptiste Subwoofers 52 19th March 2004 11:47 AM
Copyright ©1999-2017 diyAudio
