Old 17th July 2006, 06:40 PM   #1
soloxp is offline soloxp  United States
Default Rumble Filter
I found this (PIE Adjustable Line Driver with Subsonic Filter) and was thinking about buying it. Will this work like a rumble filter. I'm still looking for a rumble filter.
http://store.xmfanstore.com/linedriver.html
Thanks Solo
Old 17th July 2006, 07:04 PM   #2
preiter is offline preiter  United States
preiter's Avatar
10 Hz sounds kind of low for a rumble filter.
A rumble filter should filter out frequencies below what the port on your sub is tuned to.
Old 17th July 2006, 08:39 PM   #3
My ports are tuned around 15-16hz.
Old 20th July 2006, 08:01 AM   #4
the posted filter/booster does not specify the steepness of the bass roll-off.
I would suggest that 2pole is too slow to be really effective.
Try building one based on 4pole (dual opamp/channel) or even 6pole (2duals/ch).
regards Andrew T.
Old 22nd July 2006, 04:09 AM   #5
paulspencer's Avatar
You should simulate with WinISD pro to determine your requirements. Look at power and the excursion curve. Add filters and see what you get.
That unit looks fairly useless.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 27th July 2006, 12:02 PM   #6
just to add : the best sort of rumble filter is a peaking second order.
It is precisely tuned to very near the port frequency and usually has
adjustable Q for precise tuning of low bass levels.
The above implies that the normal 4th order roll-off of the sub is
overdamped and that you end up with a 6th order overdamped
extended bass alignment.
If all the above is done well then you also get a built in rumble filter.
(compared to simply driving with an amplifier with flat response)
/sreten.
Turntable rumble? bereanbill Analogue Source 4 4th May 2009 08:57 PM
Implementing a Rumble Filter before the Amp? Bogie Subwoofers 12 2nd January 2006 10:48 PM
Linkwitz Transform & Rumble Filter danvan Subwoofers 3 21st April 2005 02:59 PM
Passive Rumble filter? fortyquid Multi-Way 5 30th November 2003 12:25 AM
Turntable rumble lordvader Analogue Source 10 1st April 2002 11:26 AM
Page generated in 0.07327 seconds (74.30% PHP - 25.70% MySQL) with 10 queries
