Old 12th July 2006, 10:05 AM   #1
c3ham is offline c3ham  United Kingdom
Default Want to build small subwoofer
hi
I would like to try and build a small sub to replace the one i got with this kit http://www.denon.co.uk/site/frames_m...ain=prod&sub=1 but dont really have a clue where to start. I was wonder if you guys could point me in the right direction where to buy the parts and whether to build a sealed or ported box i have a budget of about £150 for the amp and driver.
Any help would be great guys
cheers
Old 12th July 2006, 10:20 AM   #2
Did it Himself
richie00boy's Avatar
On such a small budget you will need to get the most bang for your pound. That will dictate a vented box. You will be looking at 10 inch or 8 inch drivers, depending on how big a box you can tolerate. Car subwoofer drivers would be a good place to start looking.
I'd look to power the unit with a plate amp. www.cpc.co.uk do some as do www.bkelec.com
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 12th July 2006, 03:24 PM   #3
ok cheers mate
if i bought this amp http://www.bkelec.com/Modules/bsbp100.htm and this driver http://www.bkelec.com/HiFi/Drive_Uni...less/XLS10.htm what size of ported box would u recommend (trying to keep it as small as possible).
cheers
Old 12th July 2006, 06:30 PM   #4
http://www.bkelec.com/HiFi/Drive_Units/Alcone/bx10.htm
http://www.bkelec.com/HiFi/Drive_Units/Alcone/bx10p.htm
http://cpc.farnell.com/jsp/endecaSea...=LS01562&N=411
Needs around 1 cuft, 25 to 35 litres, PR tuned to 32 to 35 Hz.
The XLS10 would also need the matching PR for a small box,
gives similar response to the above in a box half the volume.
/sreten.
Old 12th July 2006, 06:31 PM   #5
Some of the paramaters like xmax were not given so I guessed. It looks like it was intended for a pretty small box but you have to tune below "optimally flat" to get much low output. Given the probable room gain I like this one which is a pretty small box good for anything down to 16' pedal stops at reasonable volume levels.
mike
Old 12th July 2006, 06:45 PM   #6
Did it Himself
The XLS10 needs a passive radiator because the box size is so small that you can't fit a vent in of the necessary dimensions. This would make a cracking little sub, but a bit over your budget? Otherwise I would have suggested it.
Old 13th July 2006, 10:18 AM   #7
a wee question how come this small sub using the xls10 doesnt have a passive radiator is it because the sub isnt very good or some other reason sorry for the stupid question but im a total newbie just trying to learn
cheers for all the help guys
Old 13th July 2006, 10:18 AM   #8
sorry forgot to post link http://www.bkelec.com/HiFi/Sub_Woofers/XLS200.htm
Old 13th July 2006, 10:34 AM   #9
Did it Himself
The passive radiator is required to get the best out of the drive unit. However, in a sealed box and with some electronic EQ it can still perform well. This way usually results in a bit smaller box.
BK must have chosen this design to suit their target price and market. It would complement your little speakers well, I dare say even show them up for how cheap they are, and be a considerable improvement on the effort you got with the set.
Old 13th July 2006, 12:24 PM   #10
If your going to buy the sub complete a Richersounds special
is a far more sensible option, should be miles better than the
25W (50W peak) Denon subwoofer.
http://www.homecinemachoice.com/cgi-...86_WHC_030.pdf
The Mission M2SAS seems well suited to job required.
/sreten.
Curved Small Thor Build Renron Multi-Way 102 20th January 2008 02:03 AM
[noob] Looking to build a really, really small sub Lindell Subwoofers 18 13th November 2007 04:16 PM
build my first full ranger,let's build another one:a small fullrange high end pc-spea then_dude Full Range 2 30th November 2005 08:54 AM
How inexpensive can you build a small 6-ch amp? mazeroth Chip Amps 9 6th November 2005 04:48 PM
Subwoofer on the small jj Subwoofers 1 24th February 2004 10:20 AM
Page generated in 0.13025 seconds (71.75% PHP - 28.25% MySQL) with 11 queries
