#71 |
hi
no i didnt use a flush trim bit just sanded it with an orbital sander the joints where nearly perfect anyway |
#72 |
You could use that, yes. It's a cheap simple option. Another is Ultracurve (more expensive but also will eq mains).
AUDIO BLOG | Bass integration guide My work: www.redspade.com.au web design studio |
#73 |
would there be any point in stuffing my box with accoustic wadding?
thanks guys |
#74 |
Did it Himself
Depending on what you use and how tight you pack it, you might notice a small difference.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#75 |
thanks for the reply richie i bought this gear http://cpc.farnell.com/jsp/endecaSea...sp?sku=LS00385 do i just add it to each of the inside faces or do i stuff the whole box with it ? and what exactly does it improve
#76 |
Stuffing lowers box Q by increasing the apparent box volume. Stuffing should fill the entire box, otherwise what you have is lining which will have a different effect - merely to absorb lower midrange frequencies, say above 100 Hz.
#77 |
Did it Himself
That stuff is BAF wadding, I use it myself. If you fill the box but don't allow it to compress much it should increase apparant box volume by a small percentage, and if you had any midrange honks they will probably go away unless they are cone modes.
| Curved Small Thor Build | Renron | Multi-Way | 102 | 20th January 2008 01:03 AM |
| [noob] Looking to build a really, really small sub | Lindell | Subwoofers | 18 | 13th November 2007 03:16 PM |
| build my first full ranger,let's build another one:a small fullrange high end pc-spea | then_dude | Full Range | 2 | 30th November 2005 07:54 AM |
| How inexpensive can you build a small 6-ch amp? | mazeroth | Chip Amps | 9 | 6th November 2005 03:48 PM |
| Subwoofer on the small | jj | Subwoofers | 1 | 24th February 2004 09:20 AM |
| Page generated in 0.07916 seconds (85.00% PHP - 15.00% MySQL) with 11 queries |
