Hey all
I built a sub box last year a 80 litre vented box, with way too small vents that chuff like hell, and lined box insides with foam, I used a 12" US goliath as a my woofer, I never finished it, right now its still here in my room as it left the work shop, perfectly sanded and smooth, im using it right now for movies and music, great little thing, but it was time to make a new project to end all!.... this box, that has been in the making for a while and has been made for 2 x 12" alpine type R 2005 model, tuned to 25hz with a pretty big slot port, and going to power it with a 500 watt rms bash plate amp which I orded from america, I have subwoofers and amp sitting in my room, recently glued box is at the work shop but I have lost faith peoples I have had to use tonnes and tonnes of body filler cause all my mdf bowed when glued and and the cuts the begin with wernt perfect, the box is now so heavy that I have dropped it 3 times and chipped/squashed 3 corners of my box while trying to sand it and get it ready for painting, while im here at home, I look at "old" box and see its in perfect nick, and that makes me feel more disapointed in the one at workshop as this one, the old one was built in a rush but turned out way better and it sounds way more solid, when I do a knuckle rap on it, to save me next time, is there a really accurate way to cut mdf boards so you get "exact" dimensions, and any tips in general to save the end box product restore my faith people |
#2 |
#3 | |
2. Meausure twice cut once. (same^) 3. Get a router with a trim bit, it has a bearing on it that when the depth is set right will trim overhang down flush with the rest of the box. This way, with proper box assembly order you can get perfect edges. 4. Finally, Im assuming you are using sawhorses and a circular saw. So to explain this picture your wood in front of you and you have already measured the cut line and drawn it and then remeasured it. The wood piece you want to keep is on your left, when you cut the left edge of the blade will go right down the line and the thickness of the blade will cut away some of the "scrap side." Now if you take the thickness of this blade and add it to the distance from the right side of the blade teeth to the outer edge of the base and take that combined measurement and cut a 4' piece of wood/aluminum to the exact width, or have a shop do it you will have a spacer that will allow you to clamp it to the line(left edge aligned). Now go buy a 4' straight edge-heavy duty is the key here, if you butt the straight edge to the spacer, clamp it to the wood (scrap side) and remove the spacer. Now you have a fence that is the perfect distance from the line so that all you have to do is keep a light pressure towards the fence and the saw will track straight and accurate every time. |
#4 |
I am in Melb., I am sure you have a similar service in Tas.This is the service...
I make accurate drawing of the box I need and I use this drawing and take my wood to the cabinet(kitchen) maker, most of them will cut them for you at a small price. Sometimes this maker also sell the wood and you can buy from them. They have precision equipment and can cut to an accuracy less than 0.5mm...Furthermore the edges are all square, I am very happy with the results I got. |
#5 |
if the box is sturdy, and well made, and you dont care that much about looks, id jstu slap some of those corner protectors you see on PA gear on them to hide the denting, toss the drivers in there, and finish to taste. In fact ive seen artifically tarnished furniture grade corner protectors, that you coudl use with a dark veneer to good effect!
DIY is about improvisation. sometimes stuff doesnt go to plan, its learning to deal with that thats half the "fun"
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!! EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!! |
#6 |
I don't suppose my comment would be considered constructive...
I also have been dissapointed with my DIY items. I've done amplifiers, subs, and random other junk, but it seems as though I always fail miserably (in my mind). My last sub turned out OK, but it was a little sloppy in music reproduction. I have ended up giving up on DIY (see my for sale thread in the Trading Post if you are interested in buying any items...). My downfall was always a lack of ability to build things properly. Something always broke. So, my advice is that you take your time, measure twice, cut once, be careful and patient. |
#7 |
My advice is keep trying. Every time I make a new sub it gets much better than the last. You have to understand that when I started I was REALLY bad.
Get the plans cut to flat pack from a cabinet maker. Or maybe have them assemble the whole box so you only have to finish it. It's still cheaper than buying a commercial speaker. |
#8 |
If you're going to repair a motorcycle, an adequate supply of gumption is the first and most important tool. If you haven't got that you might as well gather up all the other tools and put them away, because they won't do you any good.
-- Robert Pirsig The nice thing about wood is that it's adjustable. -- Teddly's Boss It's not a race. It's not a contest. -- Anon. To saw a straight line, just think pure thoughts. -- Roy Underhill Dovetail joints are easy. Just envision the joint, and remove the wood that doesn't belong. -- Roy Underhill Sandpaper is our friend. -- Dan Erickson |
#9 | |
No matter if it's amps, speakers, kitchens, bedrooms-for-the-kids, shelves (Yes, you CAN actually mess up shelves!), but I don't give a <you-know-what>! I don't care what it looks like (To a certain extend... It's the FUN of making it. Keep trying, and you'll notice that it always ends up (a little) better than the previous (Insert your last project here) you made. C'mon, MDF burns quite well, so if you fail, you can allways heat your house! I always re-use the stuff in a smaller project... My first speakers eventually ended up being tiny bits of wood, like braces and stuff (And a lot of it ended up like sawdust) Transform your subwoofer in a woofer, than a mid cabinet, and it'll end like a piece holding a supertweeter or so Bibster
Demagogue: One who preaches a doctrine he knows to be untrue to men he knows to be idiots. H.L. Mencken |
#10 |
Usually you can get the mdf cut to size at the place where you buy it.
They have a nice big machine for that that always cuts straight lines every time. |
| Current Project | ptah | Solid State | 34 | 11th December 2006 03:06 PM |
| FE206E : disapointed | mbon | Full Range | 22 | 2nd November 2004 11:18 AM |
| Current project: 1kW | Frisbee78 | Solid State | 48 | 11th February 2004 09:47 PM |
| I feel like another subwoofer project coming | VEC7OR | Subwoofers | 1 | 31st December 2003 01:44 PM |
| Page generated in 0.12010 seconds (81.57% PHP - 18.43% MySQL) with 10 queries |
