Hello,
I want to build a passive crossover for my woofer that I bought. It is a 4Ohm woofer rated at 400wattsRMS in a 1.5x1.5x2 ft. box. I would like to filter out all frequencies over 80 Hz (Basically I want it to become a subwoofer). I read somewhere that a 12mH inductor placed in series with the woofer would filter out all frequencies over 75 Hz. Is this true? If so, will it work? If not, how should I go about making a passive crossover for my woofer? Are there any other factors to consider when making a crossover for 1 speaker? |
#2 |
From xover simulator, a 12mH inductor in series w/ 4ohms will yield an Fc of 53hz. But remember, one inductor is a 6dB/octave crossover(@100hz it will only be down about 6dB). About 8mH will yield the Fc of 80hz.
Question, do you have a subwoofer xover built into your receiver? |
#3 |
Crossing over this low has its challenges but it can be done. Finding an inductor as big as nunayafb suggested that has a low DCR and an air core, means a little more than a few dollars.
When you do this, you might find that the rolloff around the crossover frequency is a little sudden. This will be due to the impedance peak, you may need to play with the values to get it right. If the impedance peak is too close to 80Hz, you may find you can't cross there without compensating for the peak or going active. You will probably want to add an RC network across the woofer to balance out the impedance rise in the midrange so you don't get a peak there. |
#4 | ||
#5 |
As a releated question..
What is the result of mechanically choking a woofer? Many years back I threw together a very quick and dirty passive "subwoofer" and choked it by putting a ring of dense foam around the speaker face. Placing it face down and adjusting the height from the floor (very close) to just about the point where I could no longer localize the sound, I was suprised at how well it seemed to integrate with my speakers. I had no way to measure what was taking place. What is, after all, the effective difference between electronically choking high frequencies and physically doing so (let's say momentarily, with a pillow)? ...assuming, for arguments' sake, that the "pillow" is able to be situated so that it doesn't damp cone movement. |
#6 |
It is better to use active filters for subwoofers. Subs need at least 12db/oct (better 18db / oct or even 24 db/oct) filters. With passive filters , you would need to equalise woofer's impedance , as already mentioned. You need additional RLC circuit. The huge quality coils and capacitors are needed.This is usually quite expensive.That's why almost all subs use active filters. A single coil (6db/oct) filter is not good for a sub. Regards, Lukas. |
#7 | ||||
When you read that, notice the impedance peak below the region the zobel deals with. This is due to the woofer's natural resonance, the one most spoken about. Your crossover will not work on top of that peak. You have three choices: 1. Cross over a bit higher. 2. Quote:
#8 | |
#9 |
Yes, you can filter the signal so that only the bass is amplified and fed to the speaker. You won't, however, do it with an 8mH inductor. The 8mH applies only to the 8 ohms which is only found at the speaker.
There are many options, some as simple as using a well selected and placed capacitor in your signal path. If this is your first use of active filtering, you might find it useful to purchase an active filtering kit consisting of an op-amp with filtering components and instructions for selecting your desired frequencies. Others may have a better idea. |
#10 |
Is that basically the function of these FMOD crossovers?
http://www.partsexpress.com/webpage....nufacturer=265 I've often wondered about the 25.00 price of these. Are they simply a "well selected and placed capacitor"? |
| SUBWoofer vs. Woofer | 901Fixer | Subwoofers | 22 | 27th November 2009 03:01 PM |
| Vintage AR subwoofer - woofer replacements? | midside | Subwoofers | 0 | 8th May 2009 03:05 AM |
| what sub woofer or pair of subwoofer is/are compatible with my amps | victorioarvin | Subwoofers | 2 | 21st July 2008 12:38 AM |
| Looking some Seas Woofer to make my HT Subwoofer. | samsagaz | Subwoofers | 11 | 8th June 2008 01:37 PM |
| subwoofer/woofer to go up to 80-100hz? | Guijs | Subwoofers | 2 | 24th October 2005 08:23 PM |
| Page generated in 0.11210 seconds (83.29% PHP - 16.71% MySQL) with 10 queries |
