Old 7th July 2006, 07:56 AM   #1
Send a message via AIM to masterjr33 Send a message via MSN to masterjr33
Default Horn type sub/ sealed end volume?
I was thinking of making a horn type of sub enclosure. My main concern was the size of the sealed end on a box like I'm pondering. Do I treat it as a bandpass. I assumed that the sealed end would be able to be made smaller due to the loading the sub sees in front of it. Can anyone enlighten me? There is a small image attached so you can get the jist of what is going on in my head. I can make that as tall as I need and change angles and depth to suite my drivers need. The driver I have is listed in my other thread, " a new baby in the house". For a few specs,15 RE 3,2/ QMS 6,37/ Qes ,531/ Qts ,49/ Fs 20hz/ Vas 157/ Freq 16-300hz/
(Vb): 1.50 cu. ft. sealed recommended..
With a sealed box I get a huge peak around 60hz and a sharp taper under 40hz even with a 20hz FS. With a large ported box I got a nice looking deep curve but my excursion went nuts around 30Hz and lower even with a port tune of 16Hz.
The driver is on its way and with only 35$ in it I dont mind wasting a bit of money on MDF.
The only tools I have are a tone generator and a crappy 30$ SPL meter. Are there any links to designs like this so I may go over the principles involved. Any info on calculating the angles and sizes of the loading area, or is it trial and error.
Old 7th July 2006, 08:39 AM   #2
Volenti is offline Volenti  Australia
Download hornresp , it's a free horn design simulator, it will let you see the effect of the rear chamber volume and predicted response of your horn.
Old 7th July 2006, 09:00 AM   #3
djk is offline djk
djk's Avatar
It will have to be big to get any bass at all.
http://www.geocities.com/loudspeakerguru/DWG60.png
http://www.geocities.com/loudspeakerguru/DWG60b.png
Main site:
This one looks good too:
http://www.geocities.com/loudspeakerguru/DWG59.png
This would be simple:
http://www.speakerstore.nl/index.php...pg=12&prjID=33
It is kind of a DIY version of this:
http://www.danleysoundlabs.com/pdf/D...ec%20Sheet.pdf
Q: Optimal Sealed Volume / Peerless 830986 speaker Full Range 0 20th December 2008 03:41 PM
Volume sealed/ported enclosure for W18NX tf1216 Multi-Way 0 5th April 2006 04:25 PM
DIY Azura/Oris type horn BTW Full Range 0 12th October 2005 12:24 PM
effects of volume in sealed enclosure? Infinity_Addict Car Audio 12 12th June 2005 12:00 PM
Question on sealed box volume vs. shape ashwin Multi-Way 7 21st October 2003 03:00 PM
Page generated in 0.07847 seconds (71.89% PHP - 28.11% MySQL) with 11 queries
