#391 | |
a few years ago my boss at a local electronics shop gave me 3 of the ribbon drivers sans boxes, two were nearly mint, one was taken apart, the good ones were alittle worn out but sounded so very good even without boxes..... sadly the two working ones were 'taken' off my hands when I lost a storage locker for non-payment... I still have the disected one in my dad's basement... does anyone have information that I could use to resurrect it and maybe build it a mate? I know this is wrong post for this but I have been searching high and low for info for these drivers |
#392 |
#393 |
Clairion and Kenwood both make a 32" driver but is it needed?
If you just want to reproduce 8hz You could build a transmission line enclosure for an 18" driver and that should achieve frequencies far too low for human hearing such as 8 hz! On the other hand you might just want to have a bigass sub! does this have to be a "conventional" subwoofer? you can get a servo motor and build a woofer to be 99" if you want, check out the Adire audio Parthenon. I think that one was 44" I'll post a pic of it below |
#394 |
any size of driver can produce any frequency.
The weight and size of the driver limits the high frequency. The weight and size and Xmax limits the SPL of the low frequency. |
#395 | |
#396 |
Have you considered variable mass passive radiators?
You could run 1 driver and put it in an enclosure with several passive radiators to conserve amplifier power, as well as achieve extremely low frequencies at moderate SPL levels. Oh and the variable mass p.r.'s you can tune them yourself by adding weight to the rear of the cone, so it shouldn't be very difficult to get 8hz. Here's the specs from audiopulse on their passives, and it looks like all but the 10" are capable of 8hz or lower!!! 10″ 12″ 15″ 18″ Qms Variable Variable Variable Variable Mms 0.5 - 2 kg 0.5 - 2 kg 0.5 - 2 kg 0.5 - 2 kg Fs 10 - 24 Hz 8 - 22 Hz 7 - 20 Hz 7 - 20 Hz Sd 0.032 m² 0.052 m² 0.083 m² 0.110 m² you can learn more about variable mass passive radiators at www.audiopulse.com |
| Giant BIB's For Sale in MN | pjanda1 | Swap Meet | 3 | 9th July 2009 01:20 AM |
| 1 giant subwoofer + bass trap or 2 smaller ones? | santiu | Subwoofers | 3 | 28th December 2007 04:47 AM |
| ZEN vs GOLIATH (the giant guy) | Trist | Pass Labs | 3 | 22nd December 2001 05:36 AM |
