Ok i am a bit slow, is there some calculation given an amount of watts and sensitivty that tells you a theoretical max spl? For example I have SoundStream Tarantual series T4-15 with a 91db at 1 watt at 1 meter, and will be pushing those with a 2000 watt rm Picasso PCA200D amp also from soundstream. Without sitting there figuring out exponents (2, 4, 8, 16, 32, 64, 128,256,512,1024,2048) i know this because of computer programming lol. By my faulty calculations i would only hit around 124db. I think that is right, 11 doubles in power, 3db gain for a total gain of 33db added to a sensitivity of 91db = 124. However on 1000 watts and 2 10" in a ported box i hit 138.9 on a term lab meter (official meter of db drags) and the box was to small for the speakers, and the starting sensitivity was only 82. Something just don't add up, with 2 15"'s seeing 2000 watts i should be in the 145-150 on the term-lab meters.
anyone know how to figure out what the theoretical SPL should be. I use winisd and it says the same 124db, and only like 110db on my 10's. |
#2 |
In house and car there are room and cabin gain, these increase spl tenfold up an extra 10 - 30 db, for reasons I cant fully explain, but I know is right
#3 |
the formula for sound pressure level increase ,not power is db=20*log(p2/p1)so for example. if p2=say 100 watts, p1=1 watt, log of 100/1 is the same as log 100(essentially)=2, then 20 * 2 is 40, therefore total accoustical db =91+40=133
similarly 1000watts=:136 dBfor power db the formula is dB=10*10log(p2/p1) this is with the assuption that Z=2 ohms total..not 1/2 ohm of course. Q?: what does SS use for spl, 91 is posted but is that 2 Ohms (voice coils in series) or 1/2 ohm (VC in ll)? also in house there may be as much as 9db "room gain" and upto 12 or 15 db "car gain"..as previously stated.
stew ☮ -"A sane man in an insane world appears insane." |
#4 |
nt
| is it correct to calculate OTL? | sam8888ysl | Tubes / Valves | 15 | 26th November 2007 05:48 AM |
| How to calculate the BL of driver | p_eric | Subwoofers | 21 | 3rd November 2006 11:52 AM |
| help ! how to calculate?????????? | bogdan_borko | Solid State | 3 | 18th January 2006 10:15 PM |
| Calculate BL | Dave Jones | Multi-Way | 19 | 8th May 2004 01:16 AM |
| Calculate BL? | Dave Jones | Multi-Way | 3 | 4th May 2004 08:04 PM |
| Page generated in 0.08338 seconds (64.80% PHP - 35.20% MySQL) with 10 queries |
