Old 1st July 2006, 09:41 AM   #1
kyselym is offline kyselym  Czech Republic
Default Dayton vs Seas
Hi
I have DD8mkII speakers (from Tony Gee) made in closed box. I want to add subs. Firstly with Tony we decided to do it with seas L26. But my local distributor is very slow!!(have ordered them 6moths ago) I decided to order speakres in USA. So now have many opptions.
I want to stay with al cones.
these are my options:
http://www.partsexpress.com/pe/showd...number=295-460
http://www.partsexpress.com/pe/showd...number=295-464
http://www.partsexpress.com/pe/showd...number=295-468
seas L26RFXP
firstly planed to cross passively but now tend to active crossover. If I use daytons would use 2 for same impedance (8ohm)
also have in mind to build it like this: closed box, one woof fireing inside second outside. This should provide less distortion. Don't know much about this... are there any info? can you link me something?
sorry for english
any help appreciated
Old 1st July 2006, 07:08 PM   #2
Definitely go with the 15" versions for lower distortion.
Could you explain the box configuration more clearly? Perhaps this link might help:
http://www.diysubwoofers.org/
Old 2nd July 2006, 08:07 AM   #3
thanks for reply
well I know 15" will give less distortion but will need much space. I dont want this for PA applications. This will be HT sub in normal room with max 6x6 m
At the moment I think of 2x12" sub. I have photos of two designs. This is the one I was describing
Old 2nd July 2006, 08:12 AM   #4
second (needs less box volume than first one but slightly more distortion)
Old 2nd July 2006, 05:01 PM   #5
if you like alumium cones,check this one out.i have 4 in 2sealed boxes in a push-pull.very tight and clean
http://www.madisound.com/cgi-bin/ind....5515&pid=1809
Old 3rd July 2006, 12:56 AM   #6
LineSource's Avatar
kyselym
My HT is a 5:0 set up with 3-way speakers instead of satellites and single central sub. The front stereo 3-ways are ideal for stereo listening, and having two woofers breaks up the room modes more than one sub. If you cross satellites to a sub above 60 Hz you start to lose some stereo imaging information.
You may want to read some of the posts comparing 3-way HT vs. satellite + sub.
Old 3rd July 2006, 02:15 AM   #7
F1 FAN is offline F1 FAN  Canada
Hi chaine, until I read your post I was not aware of these particular Vifa woofers.Are they fairly new?
They look like excellent choices for sealed box use which I much prefer over vented. I bet using 2 pairs push pull is scary good.
Old 3rd July 2006, 02:44 AM   #8
i seam to be the only one who as used them on this forum!!i've suggested them to people but nobody has tried.this is one great little subwoofer.it's the most musical sub i ever heard ,with some very nice punch.i'm only using one pair push pull right now as i have not finished the second box yet and yes it's "scary good" just with 2.4 may be overkill-we will see.
yes it is a odd woofer for vifa,but as far as i can tell,according to solen-it was a custom design for totem acoustic.
Old 3rd July 2006, 03:21 AM   #9
AH! now that you mention it ,that unique carbon fibre dust cap(or is it a phase plug) does look exactly like the one in Totems subwoofer.
I think I will check with Solen for price and availability.
BTW overkill is always a good thing.
Old 3rd July 2006, 12:58 PM   #10
solen does not have them,just madisound
Dayton RS28A-4 vs Seas 27TBFCG JimOfOakCreek Multi-Way 4 30th January 2009 04:24 AM
Dayton, Audax,Seas rinx Multi-Way 7 30th October 2007 02:04 AM
Seas P17REX & Dayton RS180 omarmipi Swap Meet 3 14th March 2006 09:34 PM
Dayton DA175-8 and Seas 27 TBC/G golo Multi-Way 8 16th November 2005 01:05 PM
Dayton Rs 7 + seas 27tdfc MTM bhg41088 Multi-Way 3 21st August 2005 07:15 PM
Page generated in 0.10608 seconds (78.69% PHP - 21.31% MySQL) with 11 queries
