Old 28th March 2010, 02:54 AM   #41
jwmbro is offline jwmbro  United States
jwmbro's Avatar
Originally Posted by markus76 View Post
What do you mean by "subsonic"? The first mode would be much lower in frequency. But we're talking about acoustically small rooms, not halls.
Sorry, I meant infrasonic.
Old 28th March 2010, 02:55 AM   #42
Originally Posted by davygrvy View Post
An EQ can not change the modal behavior of a room. If the output of your speakers are heavy at 50Hz, sure, use an EQ to fix that. If your room has a build-up at the listening position at 50Hz, don't use an EQ to fix that. You should install some bass traps instead.
let's say the variance at some problem frequency is 10dB from one side of the couch to the other. Using an EQ does nothing to change the variance problem.
With enough force, I can use a hammer to drive a screw, but it isn't the correct tool.
Only multiple subs or an unpractical amount of absorption can change the seat to seat variance. If one has to optimize a single position only, EQing can be an easy fix.
This is the frequency response at my listening position (one subwoofer in a room corner, elevated to 3 ft; DSpeaker Anti-Mode 8033):
Old 28th March 2010, 03:04 AM   #43
jcx is offline jcx  United States
I believe Toole and Geddes both point to multiple subs in diverse spatial positions to give different mode couplings for each, then you can have enough degrees of freedom for eq of the multiple subs to give OK response over a reasonable listening region
Old 29th March 2010, 01:10 AM   #44
davygrvy's Avatar
There's more in the toolbox than just absorption... diffraction from an LFD (which is big) and specular with regards to the wall and ceiling angles. Sonotubes can make great helmholtz resonators and even act as diffusers when mounted on the wall.
Think out of the box
Old 29th March 2010, 02:12 AM   #45
Sounds not very practical for domestic living rooms.
Old 29th March 2010, 02:34 AM   #46
davygrvy's Avatar
sonotube resonators, easy
Old 29th March 2010, 12:51 PM   #47
Building something might be easy but it's still not practical for listening spaces that double as living rooms. What you really want is effective broadband low frequency absorption that works below and around a room's Schröder frequency. Single Helmholtzabsorbers are not flexible and effective enough for their size.
room gain loudness pxr5 Multi-Way 7 13th September 2004 04:50 AM
Room gain Vikash Multi-Way 31 13th March 2004 10:10 AM
Room gain Raka Multi-Way 6 16th September 2003 08:13 AM
Room Gain Ignite Multi-Way 5 12th March 2003 01:10 PM
Page generated in 0.09897 seconds (78.99% PHP - 21.01% MySQL) with 10 queries
