Old 29th June 2006, 02:22 PM   #1
bungy is offline bungy  United Kingdom
Default Seas al cone sub project
I am planning a DIY sub project based on the 10" Seas prestige Aluminium cone L26RFX.
I am basing the look on the Cain&cain model:
Cain&cain
It is mainly to be used for music but will also be connected to a 5.1 setup. So i am considering using a sealed box.
I have run it through winISD and the box volume is showing 50 litres but on the Seas site:
Seas site
it indicates that a sealed enclosure should be 61-71l..i am wondering which i should follow and whether it will make any difference if it is not perfect size.?
Second question is which plate amp to use either the BK electric (250Wish) or the rythmic audio (250W). or should it be larger eg 350W.?
Thanks in advance, any comments would be very welcome.
Old 29th June 2006, 03:53 PM   #2
Use WinISDpro to model the amount of power you''ll need.
Sealed boxes are very forgiving regarding volume changes,
a well stuffed box of 50L should be fine. If you make it bigger
I'd say ~ 65L is your maximum as a bigger driver would be
better IMO, (though the excursion of the 10" is very good).
Also checkout here for sub amps ;
http://cpc.farnell.com/jsp/home/homepage.jsp
/sreten.
Old 30th June 2006, 07:07 AM   #3
I too had an idea to use the Seas L26 as a music sub a while back. Check out the thread "Seas L26 muscial sub", there might be some info there (if you haven't seen it already).
Seas L26 musical sub - amplifier choice
M.A.
Old 30th June 2006, 10:43 AM   #4
thanks for replies and links.
more research required i think but reckon a 250W should be fine. although 350W would give me greater flexibility if i choose to change driver in the future.
I just love the look of the seas Al cone so i think i will just get on and build it.just want to hear how it sounds.!
cheers
WTS: SEAS Excel W18E001 and W14CY001 Magnesium Cone Woofers Syonyde Swap Meet 10 20th April 2010 08:57 PM
New SEAS curv-cone mandoman Multi-Way 14 1st June 2009 03:28 PM
WTB: SEAS W15CY001 5" Mag cone (pair) ludcam Swap Meet 2 22nd February 2009 02:45 AM
seas T14RCY/P-H and TPX cone jomatecc Multi-Way 1 30th October 2008 10:01 PM
Seas 11F-lGWD full range with whizzer cone capslock Full Range 1 7th October 2005 06:26 AM
Page generated in 0.08182 seconds (70.03% PHP - 29.97% MySQL) with 10 queries
