Old 19th June 2006, 06:45 PM   #1
Default what peerless driver?
Hi, I'm planning to build a sub, and I came across two driver from peerless:
Peerless SLS-12
http://www.tymphany.com/datasheet/printview.php?id=38
Peerless CC-260
http://www.tymphany.com/datasheet/printview.php?id=191
From a quick simulation with winISD they both reach low F3. I don't have problem of building big cabinet and neither of space. I'm going to use the sub with a pair of B&W monitor. What driver should I buy? wich has the best quality? from what I see the SLS series is a raplacement of the Classic series, right?
thank you very much
Old 19th June 2006, 10:01 PM   #2
Notax is offline Notax  Montenegro
Notax's Avatar
Active or passive?
Old 19th June 2006, 10:19 PM   #3
The second driver appears to have been discontinued.
Any technology sufficiently advanced is indistinguishable from magic
Old 20th June 2006, 08:42 AM   #4
Notax's Avatar
So, its better the first.
I would go for closed box.
1. Vc=75 L for Qtc=0.71 Fc=49 Hz
2. Vc=95 L for Qtc=0.6 Fc=45 Hz
3. Vc=125 L for Qtc=0.5 Fc=41.5 Hz
Try 2. Vc=95 L, x-over 12dB/oct. at 75-80 Hz.
It could be something about 87-88 dB/1W/1m.
Monitors should be less. If its not, with this unit, you must go on bass-reflex (90-91 dB) or active.
Old 20th June 2006, 12:34 PM   #5
I made some simulation with lspcad lite:
for the first driver 309 liters with 2 reflex tube 10cm diamater 16cm long, so it goes around 21hz
for the second
131 liters reflex tube 10cm diameter and 26cm long and so we're again near 20hz
it's active, I already found a good amplifier with 100w on 8ohm
why? is there some reason? because dicontinued means just that they no longer produce it, not that the newer version of thing should be necessary better. The big difference, to my "audio rookie" eyes, is that the first is 30cm with paper cone and the second is 24cm with polypropylene cone.
If the quality is equal or very similar naturally I would choose the first because it's bigger, and it's newer and if I'll broke it( but I don't think so) I will get better support.
thank you to all
Old 20th June 2006, 01:37 PM   #6
Notax's Avatar
for the second
thank you to all
Eternal story about simulations. If you do it, you will blue it.
Did you see anywhere/anytime 310 L bass-reflex box with 30 cm bass?
If you go with BR: Vb=110L, Fb=28.5-29.5 Hz, Dt=100 mm, Lt=160-190mm. Don"t ask how I calculate this.
Old 24th June 2006, 08:01 AM   #7
MJS is offline MJS  Spain
MJS's Avatar
I have the SLS12 in a closed box of 86 liters and my measurements are a f-6 of 27 Hz
The sound is very good and natural
Do you have an especial interest in BR?
Regards ( and sorry for my english)
Miguel
Old 24th June 2006, 09:40 PM   #8
Thank you Miguel for sharing your experience, finally I found someone who tested on ears these speaker.
I ordered the SLS 10.
well, I have special interest for BR because I can get lower F3.
But If I can get F3 30hz with a closed I would be happy, but I think it's impossible.
How good is Peerless 850136 as sub driver? goldyrathore Subwoofers 12 14th April 2011 09:02 PM
enclosure suggestions for peerless driver BWRX Subwoofers 13 18th November 2008 03:00 AM
What think about peerless PPB driver Idefixes Multi-Way 21 8th September 2008 12:08 PM
Peerless Driver Choices Woe fishball79 Multi-Way 11 5th July 2003 11:56 PM
sub using Peerless driver trespasser_guy Multi-Way 7 25th March 2003 05:17 PM
Page generated in 0.09748 seconds (86.50% PHP - 13.50% MySQL) with 10 queries
