Old 18th June 2006, 02:51 PM   #1
vadi is offline vadi  Austria
vadi's Avatar
Question SPL question of a HT sub
Hi!
I'd like to ask if I understand this correctly:
Do you have to build your sub to play as loud as ALL the satellites in a HT setup together?
For example if there was an explosion in the front and another in the rear the sub would have to play twice as loud since the two explosions add up, wouldn't it?
What do you think?
Greetings,
Sladjan
Old 18th June 2006, 03:21 PM   #2
Send a message via MSN to xstephanx
since the LFE channel is mono, and the bass coming out of it is mostly synthesized, it will play as loud as the person who mixed it wants it to, so pretty much its a matter of weather or not they decided to sum the explosions, its also up to them how loud the sum of the explosions are.
CREEEAAAAAMMMMM CHEEEEEESSSSSSEEEEEEE!!!!!
EEEEESSSSEEEEEEHC MMMMMAAAAAEEEERRCCC!!!!
Old 18th June 2006, 04:02 PM   #3
vadi's Avatar
Hi!
Sorry, I wasn't clear that I thought about Sub-Sat systems. There the Sub plays the bass of the satellites too.
I guess it's all about the hardware which does the bass redirection?
Sladjan
Old 18th June 2006, 06:34 PM   #4
well hwo i think about it, when you sum stuff to mono, you dont get a 3db boost, so im guessing that the way it redirects bass, it keeps it at a constant level.
but i coudl be wrong! this is just my logic.
Old 18th June 2006, 07:18 PM   #5
RobWells's Avatar
I've read a few times that if all speakers are set to small then yes, the sub does need to be able to go louder to cover the extra re-directed bass.
At reference level all speakers large, sub needs to do 115dB
All speakers small, sub needs to hit 121dB.
Rob.
Old 18th June 2006, 07:57 PM   #6
vadi's Avatar
Thanks!
Greetings,
Sladjan
Old 18th June 2006, 08:40 PM   #7
GM is offline GM  United States
GM's Avatar
Greets!
Right, bass management re-directs it, though often there's little LFE content in the surround channels.
FYI, technically it's 115 + 10*Log10(number of channels), so for five channels it's ~122 dB/listening position, six = ~122.8 dB, etc., though unless the room is quite large, its gain will reduce this somewhat. Still, ideally you plan for the worst case and when not needed, it lowers distortion.
GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents.
newbie with input tran. question and wiring question imo Solid State 0 18th January 2006 10:10 PM
Capacitor Question /question on cap TunaFish Tubes / Valves 14 12th January 2004 02:23 AM
PS question - tformer question actually breguetphile Chip Amps 2 30th May 2003 01:29 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
Page generated in 0.08549 seconds (74.44% PHP - 25.56% MySQL) with 10 queries
