Haha this might seem like a ridiculous question
I realize it might reasonate and i assume theres a reason they dont make metal speaker boxes I plan on making it a down firing sub with the magfnet in the buddha and the cone firing towards the floor. So if you think this is a terrible idea please lt me know.thank you kindly |
#2 |
Possible? Yeah sure. Terrible idea? Maybe. Assuming the buddha
is completely sealed and thats the tye of enclosure your going for then it might not be terrible, as long as the statues internal volume matches the specs required by your 'woofer. The main problems with your project is the location, and the material its made of. Positioning the sub on the underside of the statue is ok as long as it doesnt strike anything when in use.(Check its x-max rating). And as for the material... Even though it doesnt flex, resonance may be a problem unless your application is pretty low-powered. |
#3 |
Speakerholic
Is it a two piece cast?
Can you give us an idea as to the thickness and overall volume? |
#4 |
probably 4 or 5 cubed feet... and about half a centimeter thick... its a shape of a buddha sitting down
#5 |
Piglicker,
I think it's a great idea. Probably the only resonance control needed would be in the base due to the non-parallel shape of the rest of the interior. I'd go with some kind of interior coating just in case there are some pinhole leaks in the brass. Be sure to use a great quality driver for a one of a kind sub like that.
Everyone has a photographic memory. It's just that most are out of film. |
#6 |
I'm sure a brass buddha would ring, but a subwoofer probably wouldn't produce these frequencies to start with.
I think it's a great idea. Would you consider painting the inside with bitumen? I think this could help, (like the way they do with car doors). |
#7 |
This is just a quick note about something you may not have considered. Before I go any further, let me just say that I really have no feelings one way or the other.
I don't personally know any Buddhists but I am pretty sure the Buddha statues are very sacred to them and any mods (painting evil blood dripping faces on them, positioning them to interact with other statues, sticking a big woofer up his bum) are extemely offensive to the religious community. By the way, I've actually seen the first two examples, but not the third - yet. I like the idea of a solid enclosure and it would certainly be a conversation piece, but the conversation that ensues might not be about killer bass. |
#8 |
With the right stealth in the base, no one would even know. If someone complains, just say it's Budda's massage cushion.
#9 |
That works for me. Proceed with caution (you only get one chance to cut the driver hole perfectly) and let us know.
#10 |
It's the homemade Koran fire logs that are difficult to explain.
| FS: Fostex 168 E Sigma with brass rings | TomekZ | Swap Meet | 10 | 16th February 2009 01:26 AM |
| What flux for soldering old brass? | Pbassred | Solid State | 5 | 5th December 2007 10:35 AM |
| FS: Rega tonearm VTA nut (brass) | krishu | Swap Meet | 0 | 2nd November 2004 04:16 PM |
| UK Source for brass bar? | penance | Everything Else | 6 | 4th October 2004 10:49 AM |
| Brass Buss Bar | kilowattski | Solid State | 6 | 12th October 2003 07:06 AM |
| Page generated in 0.10669 seconds (83.02% PHP - 16.98% MySQL) with 10 queries |
