Old 12th June 2006, 11:35 PM   #1
Default Port noise
Hey guys,
So I just hooked up my Snell SUB1800 to my new Behringer EP2500 and its sounding a little funny. If I turn up the volume past halfway on the amp the clip light goes off, and I'm getting A LOT of noise from the ports. There is so much air moving so fast through the port that is kinda whistling or making the "chuffing" noise. Any tips on how to fix this? Will making the ports longer help at all? Any help will be much appreciated.
Also, Im using a Paradigm X-20 crossover, and even at the lowest cutoff of 35Hz im getting sounds other than just bass coming through when its at very low volumes. Could this be because I'm using low level inputs instead of speaker level inputs?
Thanks for all the help guys.
Old 13th June 2006, 12:03 AM   #2
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
1. Make sure the port is flared/radiused
2. Increase the port cross-sectional area
Search either this group or the loudspeaker group for "port" and you will find a thread of someone who did a lot of port experiments and came up with a ratio for the port opening to the port diameter, also, an excel spreadsheet for the air velocity inside the port.
I found my copy of the link:
http://www.users.bigpond.com/bcolliso/port-flares.htm
Audio DIY Page
FOLLOWMY529.COM - Subscribe and follow the performance of my daughter's 529 College Saving Account.
Old 13th June 2006, 08:39 AM   #3
Default what's port noise?
what's port noise?thanks
Old 13th June 2006, 09:09 AM   #4
Sonusthree's Avatar
Port noise is when you can actually hear the air moving through the reflex port.
Martin
Old 13th June 2006, 10:10 AM   #5
Did it Himself
richie00boy's Avatar
You need more cross-sectional area and/or lower tuning.
You will experience some bleed of sound if you put your ear right to the sub. the only way to avoid it is to use a steeper crossover. Unless it's a noticeable problem in actual use it's nothing to worry about. It's nothing to do with using high- or low-level input.
The clip light coming on with just half dial setting is nothing to worry about either. The dial is justy the input sensitivity so a louder source will not need as much on the dial to sound the same as a quieter source. It's perfectly possible to drive an amp to full output with half dial or less if the source is strong enough.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Old 13th June 2006, 10:13 AM   #6
Default oh,i see! thank you very much!
i'am coming here to improve my English,meanwhile,i like hi-fi audio very much.i made a pair of sound boxes last month,but i don't know how to post the pictures here.
Old 13th June 2006, 12:27 PM   #7
Cloth Ears's Avatar
- or -
3. Use a port shaped like a rocket motor.
http://www.haliaetus.com/va/haliaetus.html (go to 'technology'). Unfortunately the AES 116 paper "Sound source design in the very low frequency domain." is no longer attached to the website. But it made interesting reading - and the gist of it is shown on the website. Basically, you can get a bigger volume of air flowing through a smaller port than via conventional flaring or using a constant radius port.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
port noise minimise Artmaster Subwoofers 26 1st December 2004 06:08 AM
port turbulent jet noise. any advice? Artmaster Multi-Way 32 6th October 2004 06:11 AM
Port noise problem ernieretief Multi-Way 9 4th August 2003 08:11 PM
Port Noise, Wind Speed................. OMNIFEX Multi-Way 20 13th April 2003 04:27 PM
Port Noise Redeye Multi-Way 19 11th February 2003 09:47 PM
Page generated in 0.08627 seconds (75.96% PHP - 24.04% MySQL) with 11 queries
