Old 14th June 2006, 03:55 AM   #11
Very, very nice job, Renato.
Any chance you could post a graph of frequency response, in-room?
Bosso
Old 22nd August 2006, 04:05 AM   #12
Xmax BR is offline Xmax BR  Brazil
Xmax BR's Avatar
Default New Toy :)
Dears,
I finished one new subwoofer to my friend...
Look more pics here: http://www.mrweb.com.br/fvm/meliante/
Tks,
Renato
Old 22nd August 2006, 01:36 PM   #13
This just in: you have mad skills, my friend.
I have been planning to make stereo subs as bases for my MTMs and your project has given me an alternative approach to consider for two 12s.
Impressive, and thanks for sharing.
Old 23rd August 2006, 11:54 PM   #14
Ap is offline Ap
Ap's Avatar
Can someone explain the idea of a push-push subwoofer to me?
Is the box volume twice that of a single driver & are the drivers wired in same or reverse polarity? Thanks.
Old 24th August 2006, 03:22 PM   #15
imjatse is offline imjatse  United States
Great work on both those subs! It really looks like you put a lot of thought into the internal design based on the shots on your site.
Old 25th August 2006, 02:44 AM   #16
Push-push generally means the woofers are mounted in the same orientation and are powered in phase. "push-push" has nothing to do with box size, although if you want to keep the same response with more drivers you have to multiply the internal volume by the according factor.
Push-pull means the woofers are mounted facing opposite directions and are powered out of phase.
Old 27th August 2006, 11:40 PM   #17
Ap is offline Ap
Ap's Avatar
Thanks - its just that this seems to be a rather unusual implementation of push-push, ie one forward firing driver & one "up"firing in the base of the enclosure.
Old 28th August 2006, 08:05 AM   #18
paulspencer's Avatar
M&K do the same thing in some of their subs.
Nice work.
My only issue is regarding using push pull with drivers not mounted on the same baffle. I emailed Linkwitz regarding having the drivers apart, and he stated the only way he would do it is with both drivers on the same baffle. It doesn't make sense to me that they should have to be that close, however I'm inclined to think twice since I regard his opinion very highly as one of the great leaders in speaker design.
AUDIO BLOG | Bass integration guide
My work: www.redspade.com.au web design studio
Old 29th August 2006, 10:16 AM   #19
Ap is offline Ap
Ap's Avatar
Thanks - thats the info I was looking for, will check out M&Ks site.
Old 1st September 2006, 06:13 AM   #20
I have been frequenting this forum for years even before i registered.... and i have to say that is one of the best designs (aesthetically) i have seen..
ABSOLUTLY BEAUTIFUL!
Finished Subwoofer - Pics Xmax BR Subwoofers 9 31st January 2009 06:44 PM
Corian Subwoofer finished Pics! camaudio Subwoofers 9 28th February 2008 01:04 AM
modify parallel push-pull EL84 to single push-pull chungtat Tubes / Valves 12 4th November 2005 12:25 AM
needed: help designing push pull subwoofer ramjet Subwoofers 3 19th April 2005 12:24 AM
Need Help On Push Pull Amplifier basiliou Solid State 15 11th June 2004 02:20 PM
Page generated in 0.10855 seconds (79.15% PHP - 20.85% MySQL) with 10 queries
