This may be a dumb question, but right now I have 2 drivers mounted clamshell in a vented box. Sounds great but for cosmetics I'd like to make feet and put one driver underneath. The port is 4"x16", so I'm wondering if firing the bottom driver right up at the port will interfere with the air flow? thanks in advance.
GhettoSQ Somewhere between Craft and Kraft |
#2 |
Speakerholic
It's probably alright but can you post a sketch?
#3 |
Having trouble inserting images...here's what it looks like now.
#4 |
Here's what I want to do:
#5 |
Did it Himself
No that won't work as you lose the compound effect of the drivers. The original design seems fine to me, the port being close to the drivers is not an issue.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
#6 |
Richie, I'm not sure I follow you on this. Can you explain how he would lose the "compound effect" by mounting the driver in the same way as his first design with the same wiring config?
Mark
Breaking speed records - http://www.mach5audio.com |
#7 |
Did it Himself
Simple:
- look at how much cone area facing the outside world there is in case 1 vs case 2. - look at how physically close the coupling is between the cones in case 1 vs case 2
#8 |
So if this isn't a compound design (read push-pull) as per other reference and commercial sites such as this one , what then would you call it?
Mark
#9 |
Did it Himself
I had always referred to what that site calls isobarik as compound (although I was aware that isobarik was another name for it), which is not the same as push-pull.
Could be getting rusty on terminology lol. Loudspeaker Design Cookbook is my bible so I'll check in there. Basically the original poster will be losing out on the box size halving aspect if he goes with design 2.
#10 |
Yea, I hear ya. I'm often faced with the same issue(s)
Most definately, by moving the driver as such the OP would have to rebuild his enclosure to compensate for the doubling Vas. Getto, how about placing the feet on the side the drivers are mounted and standing it upright? One can do wonders with a bit of grill cloth. If it sounds good to you now, there's no point in changing it... Mark
| driver placement | speedie | Multi-Way | 4 | 9th August 2009 04:22 AM |
| Driver Placement on baffle | 56oval | Multi-Way | 2 | 26th July 2009 05:25 PM |
| BIB DRIVER PLACEMENT n' others | herpaw | Full Range | 18 | 27th December 2006 08:53 AM |
| Dimensions and driver placement | Tai-Pan | Multi-Way | 5 | 16th December 2002 04:49 PM |
| Driver placement | Vivek | Multi-Way | 8 | 12th April 2002 07:58 PM |
| Page generated in 0.09421 seconds (79.48% PHP - 20.52% MySQL) with 11 queries |
